My headlights pop up at random alot, even when they are off. Usually I need to talk on them or open the hood and drop it for them to go down. Any input on the possible issue? By the way I already cleaned the grounds associated with the headlights.
Bumpers are fine but still having the popping up randomly issues. Also, the head light motors still spin after the actuation is done. Could it be a bad headlight module?
What would you suggest if indeed the cover is flexing? JB Weld it close?
If it's flexing or splitting under load, it needs to be heavily clamped and re-glued with structural epoxy, braced with a reinforcement T-bracket kit, or the motor assembly might have to be replaced. My neighbor’s C5 is doing this, currently. It’s not uncommon from what he’s saying.
