Column Lock HELP PLEASE!! 98 C5 A4 Convertible
About 2 years ago I had an issue with the head unit so decided to change it out for a double din unit, amp, and new speakers. I ran new speaker wire for the system as well. I attempted to run a backup camera, but I could not get it to work with the relay supplied by Crutchfield. While hooking up the backup camera I did have to cut and splice the reverse light wire from the BCM. That is repaired and the reverse lights work as the should. With a job and family this took about 6 months to complete. When I went to pull it out of the garage the battery was dead so I installed a new battery.
Before the radio work I had occasionally gotten the pull key message, but no issue once I pulled the key and reinserted it. The car fired right up and sounded great and I pulled it out of the garage into the driveway, then shut off. I hooked up my scanner and it shows the column lock is active. From there I have spent well over a year going down the rabbit hole with no success, so I am turning to the experts. Here is what has been done:
- Read that it could be an ignition issue, so ordered a new ignition switch and installed. Still no change. Verified the key ohms match the BCM
- Verified that the car had the recall performed
- Removed K Harness
- I started getting a "Low Voltage" issue, so replaced the voltage regulator. That resolved the issue
- Verified I do not have a CLB relay
- Installed LMC5, this still did not fix the problem.
- Worked with Richard with the LMC5, verified installation was correct. Verified ECM was acting as it should when key was turned on. Richard sent a replacement LMC5 to make sure it wasn't a bad part. Replaced and still no change
- My 98 does not have a brown wire, so that is not an issue
https://www.corvetteforum.com/forums/c5-scan-and-tune/4261386-need-tuner-to-raise-2mph-fuel-cut-off.html
I haven’t searched, but I also vaguely recall someone changing either the ECU or possibly the BCM for a similar problem — which would not be fun either.
- Removed K Harness
