Corsa Extreme Issues
Old Feb 25, 2026 | 06:39 PM
rob-cyn's Avatar
rob-cyn
Default Corsa Extreme Issues
Good evening, has anyone else had issues with their Corsa system making a loud jingling noise, especially on start up ? Corsa has been great in warrantying them and have replaced both mufflers at different times but now the noise is back louder and longer than ever so now I am wondering of it could be something else. Everything is very tight. When I smack on the exhaust I cannot replicate the sound at all. But when I start the car it sounds like a chain jingling under the car. Once everything gets some heat in it, it goes away. If you have experienced this I would appreciate your input. Thanks
Old Feb 26, 2026 | 12:11 PM
Beast's Avatar
Beast
A friend of mine had a header bolt rattling around in there after a shop installed headers and dropped a bolt in the exhaust. He found it after removing the headers himself and installing ceramic coated headers. So that’s what that noise was for the past 3 years.
Old Feb 26, 2026 | 01:06 PM
rob-cyn's Avatar
rob-cyn
I wondered if its that too and I have used a rubber mallet on the entire exhaust and I don't get any jingle at all. Every time I replaced a muffler it seems like it goes away for a little while but this time the jingle is worse than ever. when you are standing next to the car you can hear it so loudly that you would think it would be easy to find but no luck yet
Old Feb 26, 2026 | 04:49 PM
lucky131969's Avatar
lucky131969
Perhaps I am stating the obvious, but it sounds like you need to be under the car on a cold start if the noise is repeatable.
Old Feb 27, 2026 | 09:37 AM
rob-cyn's Avatar
rob-cyn
Been there. You can hear it plain as day but nobody can place where the jingle comes from. I was hoping someone else has had this issue and can tell me what fixed theirs. Like I said, Corsa has already replaced both mufflers at different times and each time it appeared to go away for a short time, but when you shake the mufflers there is nothing that sounds like something is loose in them. I will work on it again this weekend and see if I can find the issue
Old Feb 27, 2026 | 07:05 PM
Corvetteexhaustsystems's Avatar
Supporting Vendor
Corsa dealer here! A video would really be helpful here. You can text me too if it's too difficult to post!
__________________
http://www.corvetteexhaustsystems.com
sales@corvetteexhaustsystems.com
201-575-0861 (cell to call or text)
Your Ultimate Resource For Headers, Exhaust Systems & more for Corvette! I carry Corsa, Kooks, ARH, Borla, Billy Boat, Akrapovic, Capristo & Much More
Old Mar 1, 2026 | 03:15 PM
chevynor's Avatar
chevynor
I had a ratteling sound in my exhaust, It turned out to be the O2 sensors. the cap on top of the sensor had loosen up and making noise
Old Mar 1, 2026 | 03:46 PM
rob-cyn's Avatar
rob-cyn
im definitely going to check that when I get back in town. Thanks for the heads up. I have never messed with them so it would be good to check that regardless. Thanks again.
Old Mar 1, 2026 | 03:48 PM
rob-cyn's Avatar
rob-cyn
I will get that to you when I’m back in town next weekend. Thanks for reaching out.
To Corsa Extreme Issues
