Fuel door release problem
Old Mar 2, 2026 | 09:35 AM
JJG01Silver's Avatar
JJG01Silver
Default Fuel door release problem
Never had a problem with the fuel door release until yesterday. Pressed the switch and nothing. Checked the fuse ( #32 ) and it was blown so I replaced it and tried again only to blow the fuse again. Removed the connector from the actuator, replaced the fuse and pressed the switch and the fuse did not blow; so I'm pretty sure it is not the switch or a short in the wire. Can anyone tell me how to be sure it is the actuator.
Thanks in advance.
Old Mar 2, 2026 | 10:42 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you removed the connector from the actuator and it did not blow the fuse it's the actuator...basic electrical diagnostics 101.
Old Mar 2, 2026 | 08:46 PM
chevyorange's Avatar
chevyorange
On my 2000 I figured out it is the spring on the outside of the pin on the actuator. It had just lost all spring.
I was lucky enough to find a whole different actuator but I keep try old one because I'm pretty sure I can repair it just need to find the right size spring.
Old Mar 2, 2026 | 10:54 PM
Moved to C5 Tech.
To Fuel door release problem
