Prop Shaft scoring
Old Mar 7, 2026 | 07:10 PM
jdm767's Avatar
jdm767
Default Prop Shaft scoring
Hey all - 2003 C5 Z06: I had to pull my torque tube out (again) because starting from a stop (either forward or reverse) there was a grinding sound. Upon examination of the tip of the prop shaft, I can see and feel some scoring and a bit of gouging. I presume that a bad pilot bearing caused it. The pilot bearing gets changed, as a minimum. Can the prop shaft be saved, or does it need to be replaced too?
If "yes", any good sources? It's no longer made by GM... Shocking, I know...
Any tips to prevent a bad reassembly of tube to engine? I'm sure this is my fault to begin with (even though my wife wasn't around to point that out!)
Thank you!
Jeff
Old Mar 7, 2026 | 08:27 PM
base04's Avatar
base04
i see weve both pulled apart our vettes for the same reason lol, when i pulled my clutch i saw my pilot bearing was reduced to dust (not surprising my odo reads 180k) and at first i thought it was friction material from clutch, if youre concerned you can slide your pilot bearing on the shaft whiles its out and check for slop and rotation, and if youre even more concerned you can swap just the input shaft for about $200, and its pretty easy just 3 bolts in plane sight.
Old Mar 8, 2026 | 11:30 AM
C5Mat's Avatar
C5Mat
If you decide to replace it RPM transmission and texas drivetrain both sell them. There is a o-ring in the tube that the bearing on the side in question seals against, may want to get that also. Allen key bolts are also worth it in my opinion.
Old Mar 8, 2026 | 12:36 PM
helga203's Avatar
helga203
Where do you find a shaft for 200 ???
Old Mar 8, 2026 | 05:32 PM
base04's Avatar
base04
Default to helga
fiperprerformance sells one for cheap, $250 now that i checked, looks pretty similar to the texasdrivetrain or whatever one thats pretty popular
Old Mar 8, 2026 | 06:12 PM
jdm767's Avatar
jdm767
So, a follow on question - who makes a really solid pilot bearing?
Old Mar 9, 2026 | 12:01 PM
helga203's Avatar
helga203
Stock
To Prop Shaft scoring
