Wobbling over bumps
Old Mar 14, 2026 | 10:31 PM
PCPete's Avatar
PCPete
Default Wobbling over bumps
I just replaced all four tie rod ends and the tires on my 2003 convertible and have now noticed the rear end wobbles over bumps. Do I just need to get an alignment?
Old Mar 14, 2026 | 11:32 PM
jdmvette's Avatar
jdmvette
Night Owl for life
that'd be the first thing i'd do
Old Mar 17, 2026 | 11:23 AM
lucky131969's Avatar
lucky131969
An alignment is required to for your tire warranty at a minimum. Given the tie rod end replacement with new tires, the first destination should have been directly to the alignment shop.
Old Mar 17, 2026 | 03:16 PM
Ltngdrvr's Avatar
Ltngdrvr
Anytime you replace suspension components an alignment check is called for.
Have them check the control arm bushings while they are at it.
Old Mar 20, 2026 | 01:32 PM
PCPete's Avatar
PCPete
Thanks for responses. I'll be getting it aligned once the weather breaks. Forgive the ignorance, but I'm new to the performance car world and having driven rather generic/prozaic used sedans & beaters most of my life, where things like alignment were rarely an issue or even worried about, it's been an adjustment seeing to this car's needs and making sure I take care of it right, which I intend to do. Thanks again everyone!
Old Mar 20, 2026 | 01:40 PM
lucky131969
Forgive the ignorance, but I'm new to the performance car world and having driven rather generic/prozaic used sedans & beaters most of my life, where things like alignment were rarely an issue or even worried about.....
YOU not worring about the integrity and alignment of your suspension on previous vehicles does not mean it is not important. It is important on ALL vehicles. Especially when replacing suspension components and tires.
Old Apr 23, 2026 | 02:13 PM
DebRedZR1's Avatar
DebRedZR1
Moderator
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'17, '21
Definitely check alignment! Very important as noted above! Good luck
To Wobbling over bumps
