Vette C5 electrical problems
Old Mar 15, 2026 | 05:22 AM
Marks1982's Avatar
Marks1982
Cruising
Default Vette C5 electrical problems
Hi, I have long time problem with my Vette. Gives faults
P 1220, P1221 and C1278. I have been replace two time TPS sensor, battery, at first seemed to work, but at long drive it starts again. Comes “Reduced engine power”and gas pedal not working.
Things I have noticed myself:
-Often cold engine start are “Reduced engine power”(mostly I can erase it and engine works after that)
-When cold engine then engine RPM swaying up and down and sometime while drive, engine stops.(not warm engine)
-Whit warm engine comes often P1220, 1221, C1278 and sometime cant erase those errors few days.
I've taken it to the service several times, but they can't do anything, they just replace the TPS.
idont know it this normal or not, but battery goes emty when car stay about 5day.
maybe somone can help me.
Old Mar 15, 2026 | 10:25 AM
old stingray's Avatar
old stingray
It sounds like you’re got a parasitic draw,there’s several write ups here on the forum and YouTube about it. A low voltage condition will cause all kinds of electrical gremlins to pop up. Find the cause and the other problems will probably go away. Good luck!
Old Mar 15, 2026 | 11:28 AM
mmartinez's Avatar
mmartinez
I know you said that you have replaced the battery, but I would pull it and have it load tested at a nearby auto parts store. I went down the parasite draw rabbit hole several years ago, but discovered that my battery was not holding a charge. Do you have a DVM and know how to use it?
Old Mar 15, 2026 | 02:27 PM
Marks1982's Avatar
Marks1982
Cruising
Hi, sorry, but what you mean about DVM?
Old Mar 15, 2026 | 04:44 PM
feeder82's Avatar
feeder82
Digital Volt Meter
Old Mar 15, 2026 | 10:40 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
See you live in Estonia...trouble codes are NOT part numbers so find an auto electrical specialist in your area...they do not have to be Corvette specialists but have electrical experience.
To Vette C5 electrical problems
