C5 Ignition switch/dash message issue
Old Mar 18, 2026 | 01:23 PM
1arunem's Avatar
1arunem
Cruising
Default C5 Ignition switch/dash message issue
2002 C5 Z06.. 73k miles..
Need input on what I think may be an ignition switch issue..
When starting the car, if you turn key and start the car right away, several messages appear on the dash.. "Service Stabilitrac, Low Fuel, Traction Control, etc"..
However, if the codes are cleared and you turn ignition to on/acc, wait 2-3 seconds, then turn key to start/crank the car, the messages do not appear and the odometer shows as normal on the display.
As long as there is a 'pause' between turning key to on/acc position before starting, all seems normal..
Ignition switch issue or ... ?
Thanks for any input..
Old Mar 18, 2026 | 01:33 PM
lucky131969's Avatar
lucky131969
Could be. Simple voltage checks will confirm. Do you have a DMM, test light, and can you read schematics?
Old Mar 18, 2026 | 01:57 PM
1arunem's Avatar
1arunem
Cruising
DVM? yes.
Test light yes
Read schematics, not great at it but can probably manage.
I can check voltage at acc position and at crank postion, but how would I tell a difference between cranking it right away versus the pause?
Old Mar 18, 2026 | 01:59 PM
lucky131969
DVM? yes.
Test light yes
You should have a DTC codes to compliment the messages. Have you pulled codes from the DIC? All H and C are relevant.
Old Mar 18, 2026 | 02:08 PM
1arunem's Avatar
1arunem
Cruising
TCS U1000, TCS U1016
BCM U1096
SDM U1000, U1016, U1096
RADIO U1016
HVAC - NO COMM
LDCM U1016
RDCM U1016
SCM U1016
RFA U1000, RFA U1016
All "H" historical codes..
Car seems to run and drive as it should.
Old Mar 18, 2026 | 02:13 PM
jjcoledo3's Avatar
jjcoledo3
2 silver vets
I had similar issue with my 98. I now insert the key, wait about 5 seconds till gages sweep and then start. No more messages.
Old Mar 18, 2026 | 02:16 PM
lucky131969
BCM U1096
RADIO U1016
HVAC - NO COMM
LDCM U1016
RDCM U1016
SCM U1016
Yup, that's a whole lot of comm codes. I do not have access to the service manual right now. I would just look up the impacted systems and take your pick for voltage checks at the appropriate fuses in the IP electrical center. Since the problem is repeatable, this will be easy to see an absence of voltage or low voltage at the impacted fuses.
Old Mar 18, 2026 | 02:34 PM
mmartinez's Avatar
mmartinez
Your corvette has a two second fuel pump prime which helps the car start faster and doesn't have to crank over as much. I believe that you really don't have a problem as long as you wait for the two second fuel pump prime to time out.
Old Mar 18, 2026 | 02:40 PM
grinder11's Avatar
grinder11
My 2000 came with 2 keys and 2 fobs. I always used the same key for 15+ years. I started getting "pull key and wait" messages. I read somewhere online that if you already have the lock bypass kit installed and you get this message, the key is worn out. Sure enough, I tried my "new" spare key and never saw the message again. Not saying this is the issue, but thought I'd throw it out there....
Old Mar 18, 2026 | 02:41 PM
lucky131969
It's not a prime, it's a time-out. There is no such thing as priming if you just get in the car and start it normally. The pump only runs for 2 seconds if you do not turn the key from ON to START because there is no CKS output.
Old Mar 18, 2026 | 03:10 PM
1arunem's Avatar
1arunem
Cruising
So are you saying that if the car is started in a manner to induce the message, once it is cranked there will be an absence of or reduced voltage that can be detected?
I am thinking once the car is started, all voltage will be as normal since the issue only occurs as the key is turned to crank (however it immediately returns to acc once started).
I hate to ask but if you could detail when to check for voltage or lack thereof, I would be grateful.
Thanks!
Old Mar 18, 2026 | 05:05 PM
Ltngdrvr's Avatar
Ltngdrvr
I have this issue intermittently, and read it can be the switch going bad, so I bought a new switch but haven't installed it yet.
Then just a few days ago, someone on here linked a thread that talked about the harness that plugs into the switch can end up with the receiver pins get loose, not making good contact with the pins on the switch, and their solution was to take it apart and crip the receiver pins in the harness to make them make tighter contact with the pins on the switch.
One of these days, I will take mine apart and see about installing the new switch and tighten up those harness pins.
Old Mar 19, 2026 | 08:56 PM
mmartinez's Avatar
mmartinez
I need to explain that if you get in your car insert the key and immediately turn the key to the crank position your are supplying accessory power very briefly and then shutting it off when the key is in the crank position. I would let the gauges sweep and then turn the key to start the car. In my car I sometimes get the pull key wait ten seconds message and if I would immediately try to start the car it will start and then stall when I try to drive forward, because I didn't give the car enough time to display the message.
To C5 Ignition switch/dash message issue
