Hey guys, pretty new to the forum, and owning a vette. I have a 2002 C5 Z06, previous owner installed an oil cooler and put a label for 8 quarts on the the valve cover.
I decided to check the oil level today and its about 3/4 of an inch above the max line on the dipstick. Now I know he tracked the car, and I plan on doing the same. But I was wondering if this is an ok level to fill to. Or if I should change out the oil. He had a fresh change on it when I bought it from him so I do know that. Mostly just curious if I need to somehow reduce the level. From what I've searched on the forum I THINK this should be ok, but still wanted to reach out and double check.
I have an oil cooler, and fill with 7 qts when changing oil. Why? Because once you have the cooler and lines on, and filled, the rest of the system will only need what the factory capacity calls for from then on. Because it is virtually impossible to drain the cooler lines and cooler of the oil in them when the next oil change is due. You wouldn't want to, anyway. Why, again? Because this would mean you'd have no oil pressure for maybe 5-10 seconds after every oil change, because the pump would need to refill the lines and cooler with oil. Sure, you could expend a considerable amount of time, and make a big oily mess, draining and manually refilling the cooler and lines with oil after each change. IMPORTANT!!! When you first install the lines and cooler, fill them with oil the best you can before starting the engine. I've found changing oil every 3,000-4,000 miles keeps whatever oil left in the system fairly fresh, so it doesn't contaminate the new oil change. So the initial fill with the new cooler and lines may take approximately 8 qts. 7 qts from then on should work well if you're running the batwing pan...
I should have stated that I haven’t done an oil change in the car yet. But all the information you provided is awesome so thank you for that! I guess my question still remains of, should I change the oil to get the level lower or is 1/2-3/4” above the max line on the dipstick ok?
Just a though, stock engine is 6 qts. If you auto the car on a track you are allowed 7qts so considering with the oil cooler 8qts should take up the extra volume of oil. Make sense. But if you cant sleep at night take the oikl filter off drain and put it back on or just get a new oil filter to remove some oil.
I just suggested the filter because if you drop the oil plug it could get messy.
The only problem with that is that oil filter gaskets are designed for single use, not recommended to be loosened and reinstalled. The gasket deforms to the specific surface, and to the amount of torque applied when installing. It also hardens with heat and pressure, so while you could maybe get away with it in a pinch, you’d possibly be looking at developing a leak. Draining a bit from the pan when it’s cool really isn’t too hard, just keep the bolt pressed against the threads, don’t remove it entirely, draining just enough.
That's why i suggested or new one.lol Playing with fire losing that bolt. Not saying it cant be done. Not downgrading your suggestion.
You'll be fine@1/2" over. Stock capacity on my 2000 is 6-1/2 qts. Most people just throw in 7 qts and call it good. Personally, I think you'll be fine removing the filter and dumping the excess oil. Just be sure to oil the rubber gasket before reinstalling the filter, which you should always do anyway when installing a brand new filter...
Under what conditions is the oil level 3/4-inch above the max line?
Per owner manual:
In order to get an accurate reading, the oil must be warm and the vehicle must be on level ground.
Turn off the engine and give the oil a few minutes to drain back into the oil pan. If you don’t, the oil dipstick might not show the actual level.
FYI, you overfill the oil by 1 quart when you track the car, as stated above, yours might need 8 quarts total when on a track to accommodate for the oil cooler and the extra oil needed for being on a track. Maybe it’s a good idea to change the oil since you haven’t yet.
Per owner manual:
This was with the car cold, so I probably should do it the way the manual states. That being said, I don't have a manual... lol I'll go hunting on google or the forums for a copy.
