Fram/First Brands bankrupt....
Old Apr 4, 2026 | 08:58 AM
grinder11's Avatar
grinder11
Originally Posted by vette4fl
I haven’t bought a Fram filter since the Nixon administration, so whatever…
Me either. But there were a lot of companies that went down in the bankruptcy. I can actually remember when Fram and Purolator were 2 of the very best....
Old Apr 4, 2026 | 11:32 AM
Lowend's Avatar
Lowend
It's been a LONG time since Fram was any good. By the mid-90's everyone I knew was steering clear of them. Tissue paper in a recycled beer can is how one of the OG mechanics described them at a gas station I worked at as a kid.
Old Apr 6, 2026 | 07:06 AM
harleydoctor's Avatar
harleydoctor
Amen to that.
Old Apr 6, 2026 | 07:14 AM
lucky131969's Avatar
lucky131969
Can you reference one single documented catastrophic engine failure directly attributed to using a Fram oil filter.......or any oil filter brand for that matter?
Old Apr 6, 2026 | 10:28 AM
grinder11's Avatar
grinder11
Looking online, I see Purolator is now owned exclisively by Mann-Hummel, as is Wix. Seems M-H bought them outright in 2013, when they bought out Bosch, who had co-owned them with M-H since 2006. I also saw that Purolator pretty much invented oil filters way back in 1923. FWIW....
Old Apr 6, 2026 | 11:32 AM
Lowend's Avatar
Lowend
That's the thing about filters, it's pretty hard to tell if an oil filter caused an engine failure. I've certainly seen oil filters that ruptured, bled out oil caused engine failures. Couldn't tell you the brands on those.
But, cutting open the filter, the differences in quality before pretty clear pretty quickly.
A bad filter is more of a cumulative effect how much crud does it allow into the bearings... Death by 1000 cuts if you will.
Old Apr 7, 2026 | 11:25 AM
vito02's Avatar
vito02
What I'm seeing is that the Baldwin's are typical, if not slightly more 'fine' than other filters in the market. They don't advertise in the car world, so I'm not surprised if they are off the radar for people outside of commercial vehicles. Baldwin and Hastings have been the same company for a number of years.
How did you come to this opinion? Is 50% at 18 microns considered fine filtration?
I ask because I am considering trying a Baldwin oil filter.
Old Apr 7, 2026 | 11:34 AM
lucky131969
Well if you come across some any evidence to suggest that...I'd love to read about it.
Old Apr 7, 2026 | 12:06 PM
vito02's Avatar
vito02
I as well.
Old Apr 7, 2026 | 12:16 PM
Lowend's Avatar
Lowend
My point is the Baldwin is typical in it's specs, maybe on slightly on the finer particulate side of the scale. They are difficult to compare as many filter companies measure differently.
@lucky131969 I'm not sure what your trying to argue here
Evidence that having particulates in your bearings and rings causes damage?... pick up literally any engine book. That's the whole point of an oil filter, to catch those.
If you have a filter that degenerates, rips and allows stuff through - or worse yet comes apart and contributes to the contamination... that's pretty bad. If you have a filter that has a bad bypass circut and constantly allows unfiltered oil to circulate, that's a similar effect.
If you're asking what makes Fram filters lower quality, I don't have a scientific paper to cite. I have cut open a good number of filters and have to say Fram's construction was on the low quality side of things. Cardboard instead of steel etc.
Old Apr 7, 2026 | 01:09 PM
lucky131969
Not arguing, just pointing out that your perception of quality based on material construction does not necessarily translate to effectiveness or increase/decrease the likelihood of pre-mature engine failure. Regardless of the materials used, does it get the job done? Does it provide adequate filtration to protect lubricated interfaces/surfaces to extend engine life for as long as you own the car?
