Ignition switch
Old Mar 31, 2026 | 08:33 AM
Deepsix's Avatar
Deepsix
6th Gear
Default Ignition switch
Installed new ignition switch, switch activates assessories but does not start the engine.. Any ideas..??
Old Mar 31, 2026 | 09:38 AM
eric22's Avatar
eric22
Recheck connections and fuses.
Old Mar 31, 2026 | 10:51 AM
Deepsix's Avatar
Deepsix
6th Gear
Thank you..! Will do..
Old Mar 31, 2026 | 12:01 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Could it be a VATS issue?
Old Apr 1, 2026 | 05:11 PM
capeokw56's Avatar
capeokw56
Ditto... Had mine done at the dealership for just that reason.
Old Apr 1, 2026 | 05:29 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Well what year is the car and WHY was the ignition switch replaced...what electrical troubleshooting have you done ??...if none and you have no electrical experience take your car to an auto electric shop...too many variables to help you !!
Old Apr 2, 2026 | 08:41 AM
Deepsix's Avatar
Deepsix
6th Gear
No dealers here in Las Vegas, NV will work on automobiles older than 20 years.. ZO6, 25 years old. Worked fine one morning, after driving 30 minutes, stopped to pick up mail, ignition would only come on, not engage starter.. After tapping the key it started up as usual..
Old Apr 2, 2026 | 09:27 AM
C5 Diag's Avatar
C5 Diag
As I've said a million times on this Forum a dealership is the LAST place you'd want to take your car to have it diagnosed !!...they only replace parts...find an auto electric shop instead...one of a few in Las Vegas is listed below.
Old Apr 2, 2026 | 10:12 AM
Moved to C5 Tech.
To Ignition switch
