SWPS issue diagnosis
So I replaced the swps with a new one from standard motor products. It seemed at first to be fixed but now my code comes back in a different type of manner, typically within the first couple minutes of driving, sometimes before i even start moving the vehicle. And it usually is a current code, not history with the previous sensor.
So i took some measurements of the voltage to the signal pins (b/t blue and green wires). See video below. It usually shows about 2.5 V at center and then goes to around 2V 90 degrees either way. But I did notice that it goes almost to zero randomly. Is this normal? What are the expected voltages at the various steering wheel angles?
https://youtube.com/shorts/oqUUh3LYmho?si=dTCGc5ABvbynFXqy
Let me know if the video link works?
https://www.corvetteforum.com/forums...ts-needed.html
