Need help w/ Blackwing
Old Feb 21, 2003 | 11:02 PM
cgione's Avatar
cgione
Default Need help w/ Blackwing
I am trying to install a new Blackwing on my 02 coupe and am having a problem with the MAF. The metal ring on the MAF is the same size as the Blackwing plastic inlet. The rubber cuff clamp is designed to circle the Blackwing plastic inlet and the MAF slides inside the rubber assembly. This won't work as the metal ring on the MAF is the same diameter as the Blackwing housing. Has anyone out there had a similar issue and can you please HELP :banghead:
Thanks in advance
Old Feb 21, 2003 | 11:05 PM
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
Default Re: Need help w/ Blackwing (cgione)
Did you get the adaptor for the 2001+ cars?
Old Feb 21, 2003 | 11:06 PM
Patches's Avatar
Patches
Are you using the blue rubber coupler as pictured below?
Old Feb 21, 2003 | 11:15 PM
cgione's Avatar
cgione
NOOOOO I did not get any adapters. Did not know one was required. Bought from LAPD, would have thought that if a $&%@@^ adapter was required for my car thay would have told me :smash: :mad
Well now that I have the whole stock assembly out I guess I will putting it back :cry
Thanks for the help
Old Feb 21, 2003 | 11:19 PM
Quick Brick's Avatar
Quick Brick
Shaun usually asks year :smash: he will make it right ASAP :yesnod:
Old Feb 22, 2003 | 01:29 AM
kluczenk's Avatar
kluczenk
I had the same problem with the Blackwing I ordered from the LAPD Group Purchase. Even if you specified 2001+ it likely didn't have the adapter (I luckily noticed this before I took apart the stock box). Email/call Shawn at LAPD and he will send you the part. Unfortunately he would not overnight it to me so I will have to wait till next week to install, a bit disappointed there but at least I will have the right parts.
Thanks for the help
Old Feb 22, 2003 | 02:25 AM
RskyBns's Avatar
RskyBns
Default Re: Need help w/ Blackwing (Quick Brick)
Shawn usually asks year :smash: he will make it right ASAP :yesnod:
:withstupid: Ya need the adapter....that one you have is for the Pre-01 years with the 3.5" opening....the adapter for the Post-'01 cars have a 4" opening and need this adapter....it's basically a round piece of rubber.
Old Feb 22, 2003 | 07:57 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Default Re: Need help w/ Blackwing (RskyBns)
Shawn at LAPD forgot mine too! :mad You would think by now, he would know!
Old Feb 22, 2003 | 08:13 AM
SideStep's Avatar
SideStep
Default Re: Need help w/ Blackwing (Ragtop_Rob)
I got mine from LAPD last Wednesday and it DID come with the adapter.
Thanks Shawn!!! :thumbs:
:cheers:
To Need help w/ Blackwing
