But wait theres more.. CODES
Old Apr 18, 2026 | 07:44 PM
Hellzgato's Avatar
Hellzgato
Default But wait theres more.. CODES
A rather wise member once told me the first step troubleshooting any vehicle since 1996 was pulling the codes and listing them for feedback... (Clearly was valid!)
2000 Auto C5 (bears mention its been modified, Heads, Cam etc) Current issues include security light, reverse lighting inop, no crank situation.
Well, turns out I had a happy helping of those suckers! I shall do some research on each of them but for your viewing pleasure and potential input please see below. Not sure if there's a grouping as a whole I should dig into first that may also have an affect on others or just take them as they come. (I already intend to go through all the grounds as a baseline move)
10-PCM P0705 HC
28-TCS No Codes
40- BCM B0502 H
40- BCM B0507 H
40- BCM B2482 H
40- BCM B2583 H
40- BCM B2592 H
58- SDM No Codes
60- IPC No Codes
80- Radio No Codes
99- HVAC B0446 H
A0- LDCM B2282 H
A0- LDCM B2286 H
A0- LDCM B2284 H
A0- LDCM B2262 H
A0- LDCM B2264 H
A0- LDCM U1064 H
A0- LDCM U1096 H
A1- RDCM B2283 H
A1- RDCM B2287 H
A1- RDCM B2285 H
A1- RDCM B2263 H
A1- RDCM B2265 H
A1- RDCM U1064 H
A1- RDCM U1096 H
A6- SCM NO COMM
No More Codes (Nope, Thats it!)
Old Apr 18, 2026 | 07:51 PM
helga203's Avatar
helga203
10-PCM P0705 HC
28-TCS No Codes
40- BCM B0502 H
40- BCM B0507 H
40- BCM B2482 H
40- BCM B2583 H
40- BCM B2592 H
58- SDM No Codes
60- IPC No Codes
80- Radio No Codes
99- HVAC B0446 H
A0- LDCM B2282 H
A0- LDCM B2286 H
A0- LDCM B2284 H
A0- LDCM B2262 H
A0- LDCM B2264 H
A0- LDCM U1064 H
A0- LDCM U1096 H
A1- RDCM B2283 H
A1- RDCM B2287 H
A1- RDCM B2285 H
A1- RDCM B2263 H
A1- RDCM B2265 H
A1- RDCM U1064 H
A1- RDCM U1096 H
A6- SCM NO COMM
Clear the all the codes if you know how to do it. Then start from whatever codes come back.
Old Apr 18, 2026 | 08:04 PM
Hellzgato's Avatar
Hellzgato
So the PCM code and HVAC code wouldnt allow me to erase them... I erased the rest.
Will they come back without the ability to have a running key cycle? As of right now its a no crank situation.
Old Apr 18, 2026 | 08:37 PM
helga203's Avatar
helga203
Do you know how to diagnose circuits and schematic??? If so ,google no start and follow the directions on what should happen at certain times while you try to start the car. Tons and tons of info, so start there do your homework and if you get stuck at a certain point and and have a specific question when you're trying to diagnose it not just where should i start. You have to put in the time to eliminate section of the start sequence.
Old Apr 18, 2026 | 08:43 PM
Hellzgato's Avatar
Hellzgato
To a point, I'm far from proficient probably, but enough to follow bread crumbs a bit.
Based off the fact I have the P0705 "Transmission Range Sensor", combined with a no-start and no reverse lights I am starting with that and see where a replacement switch takes me (has a crack on it anyway)
As for the rest, If I can manage to get it running with the selector switch I will see if the others return. (I read an awful lot about a bad battery causing a lot of those, which the car had when I first got it)
Old Apr 19, 2026 | 06:38 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
10-PCM P0705 HC
28-TCS No Codes
40- BCM B0502 H
40- BCM B0507 H
40- BCM B2482 H
40- BCM B2583 H
40- BCM B2592 H
58- SDM No Codes
60- IPC No Codes
80- Radio No Codes
99- HVAC B0446 H
A0- LDCM B2282 H
A0- LDCM B2286 H
A0- LDCM B2284 H
A0- LDCM B2262 H
A0- LDCM B2264 H
A0- LDCM U1064 H
A0- LDCM U1096 H
A1- RDCM B2283 H
A1- RDCM B2287 H
A1- RDCM B2285 H
A1- RDCM B2263 H
A1- RDCM B2265 H
A1- RDCM U1064 H
A1- RDCM U1096 H
A6- SCM NO COMM
You ALWAYS start with having the battery load tested...the C5 starting system is pretty basic...trouble codes are not part numbers so if you don't have a factory level scan tool or electrical diagnostic ability to check the PNP switch seek out an auto electric shop in your area...you'll only be wasting your time and money...if you can't follow the electrical schematic below definitely seek out that shop.
Old Apr 19, 2026 | 06:37 PM
Hellzgato's Avatar
Hellzgato
Im also not gonna leave one that’s cracked on the car regardless. So it’s worth a shot. Otherwise yep schematic it is.
To But wait theres more.. CODES
