Sequencial shifter
Old Apr 18, 2026 | 08:41 PM
fcable's Avatar
fcable
Default Sequencial shifter
Has anyone installed a sequencial shifter on a C5/C6 Corvette T56 transmission?
Old Apr 19, 2026 | 01:20 AM
arthursc2's Avatar
arthursc2
Have you found anyone making one? The ones I see for sale aren't for torque tube cars- just traditional T56/TR6060
Old Apr 19, 2026 | 09:13 AM
-ZEEOHSIX-'s Avatar
-ZEEOHSIX-
If you're talking about something like S1 Sequential, no. No one makes something like that for the Corvette. However, sequential transmissions are available for the C5-C7's.
Old Apr 19, 2026 | 02:16 PM
fcable's Avatar
fcable
Who provides a sequencial transmission for C5 Corvettes? Thanks
Old Apr 19, 2026 | 02:18 PM
arthursc2's Avatar
arthursc2
How much do you want to spend?
6xd has probably the best and strongest box/ diff available
PPG sells a sequential gearset for the T56 housing
Old Apr 20, 2026 | 08:50 AM
-ZEEOHSIX-'s Avatar
-ZEEOHSIX-
As mentioned above, there are several options. PPG is likely the most widely known. But that doesn't mean that it's the best for your application.
https://www.ppgearbox.com/corvette-s...al-gear-system
And then for what it's worth, some folks have been actively swapping in the GM 8L90 transmission into C5s. Those can be built by aftermarket shops to do some serious work. It just depends on what you're after and why you want to switch up your transmission action.
Old Apr 20, 2026 | 09:12 AM
mykream's Avatar
mykream
The sequential shifters that are sold for T56/6060s are cool in theory... But horrible in reality.
The shift is too quick for synchronizers and blocker rings. For a faceplated gearset, it isn't too big of a deal as they need to be shifted as fast and forceful as possible.
Old Apr 21, 2026 | 12:02 PM
-ZEEOHSIX-'s Avatar
-ZEEOHSIX-
For cars with NLS built in, it's not so bad. You can even reduce the amount of spark cut between shifts for quicker shifting recovery.
Old Apr 21, 2026 | 12:08 PM
mykream's Avatar
mykream
I don't think you understand. The shifter physically shifts the gears faster than the synchros and blocker rings can handle. Has nothing to do with no lift shift.
Old Apr 21, 2026 | 05:30 PM
Lowend's Avatar
Lowend
There was a guy named Duke Langley who tried to do this on a Ultimate Street Car C5 a few years back. I don't know if he ever got it working right
Awesome car regardless
Old Apr 21, 2026 | 06:06 PM
arthursc2's Avatar
arthursc2
He did get it sorted out!
but he's on a 6XD and Winters diff
precovid it was a $30k system. I don't know what it costs now, but it's for sure the strongest trans and diff combo available for the C5/6/7 platforms
To Sequencial shifter
