advice/help post
Old Apr 20, 2026 | 07:34 PM
t82992's Avatar
t82992
1st Gear
Default advice/help post
Hi I’m making a advice/help post
Vehicle: 1999 Corvette C5
Codes:
C1226 H
C1243 H
C1292 H
Symptoms:
- ABS light on
- Service Active Handling message
- Traction control issues
Mechanic diagnosis:
- Internal brake control module (EBCM) fault
- Recommended replace/rebuild EBCM (part discontinued)
Question:
- Best place to send EBCM for rebuild?
- Is rebuild reliable vs buying used?
- Anything else I should check before removing it?
A lot of websites I go to for repairs are super confusing and they list things that aren’t related to my codes or whatnot I’m not very mechanically inclined so I don’t wanna do the wrong thing and be *** out.
Old Apr 21, 2026 | 10:09 AM
grinder11's Avatar
grinder11
The 1997-2000 EBCM's are not repairable. IF the problem is actually the EBCM, your only choice is a salvage yard. Be prepared to shell out $1,500-$2,000. So, obviously, ensure the problem is actually the EBCM. The 1226 code is the RFSS. The 1243 code is not a good one. IIRC, and I may not, I think that code means the ABS pump motor has seized or stalled. The 1292 code is the fluid pressure sensor, which could mean the master cylinder and/or the EBCM are failing. Could also be the wiring. I see they are "H" (history) codes. Have you tried clearing them?
Old Apr 21, 2026 | 11:59 AM
Smoken1's Avatar
Smoken1
ABS Fixer can fix the 1242 and 1243 codes now on the older cars
Old Apr 21, 2026 | 01:39 PM
lucky131969's Avatar
lucky131969
Not only are they repairable for limited DTCs, they are repairable for a C1243 DTC.
Old Apr 22, 2026 | 08:24 AM
grinder11's Avatar
grinder11
Must be a somewhat recent development. I know up to a few years ago they weren't repairable. At least, that's what forum members reported. From my understanding, more problems can be fixed on the '01-up EBCM's. I'm glad some progress has been made fixing the older units. Perhaps I should've simply said call ABS Fixer!
Old Apr 22, 2026 | 08:26 AM
grinder11's Avatar
grinder11
Double post, sorry.
Old Apr 22, 2026 | 05:12 PM
Gorn Captain's Avatar
Gorn Captain
Yup. Someone decided to actually rebuild them and thank providence for that! The thing with electronics, is that when they say it’s “not repairable” that means no one is WILLING to repair them. It’s finicky work and $750 is well worth it to keep another sweet C5 on the trail. Good luck OP.
To advice/help post
