Traction and abs light stays on
Old Apr 28, 2026 | 08:27 PM
joecookie01's Avatar
joecookie01
Cruising
Default Traction and abs light stays on
my traction and abs light is on so I checked the codes and do not see any of the ebcm failure codes. I do have a TCS no comm code, any idea of what the issue is
Old Apr 28, 2026 | 09:06 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
For any "No Comm" you would want to check the EBCM powers and grounds...you can start there...helps to know the model year...you should fill out your profile !!
Old Apr 29, 2026 | 01:41 PM
joecookie01
Cruising
thanks it is 1998 just plain edition no frills
Old Apr 29, 2026 | 01:53 PM
lucky131969's Avatar
lucky131969
What is a "plain" edition? Depending on the production timing, you could have a front or rear mounted EBTCM or Active Handling.
Old Apr 29, 2026 | 03:17 PM
joecookie01
Cruising
basically the standard package with 5.7 engine and automatic transmission, with abs and traction control
Old Apr 29, 2026 | 03:28 PM
lucky131969
Ok good luck.
Old Apr 29, 2026 | 03:43 PM
joecookie01
Cruising
where would the rear mounted be I am having a problem finding the unit
Old Apr 30, 2026 | 08:11 PM
joecookie01
Cruising
you were right mine is located in the back finally figured this out when it was not in front. Found a blown fuse F5 and it cleared the lights, will have to drive for awhile to make sure it stays out
To Traction and abs light stays on
