window........
Old Feb 23, 2003 | 02:34 PM
Mordenkanen's Avatar
Mordenkanen
Default window........
window won't go all the way up? stops about a 1/4 of a inch from the top? :confused:
Old Feb 23, 2003 | 02:47 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: window........ (Mordenkanen)
Saw this posted...don't know if it will help but.....
It seems to be quite a common problem for the passenger window motor to stop working. The problem seems to stem from the fact that the window does not get used very often. Try to use the windows at least once a week to keep the motors in good working order.
My '99 widow stuck recently and the best tip I received was to hold the door window button just as you close the door (fairly firmly). The tip worked perfectly.
