Please help my c5 isn’t getting any power
Old May 29, 2026 | 02:26 PM
c5yazan's Avatar
c5yazan
3rd Gear
Default Please help my c5 isn’t getting any power
So the battery is good but the car won’t start no lights on my dash trunk button won’t work it’s completely dead I was driving yesterday fine and then today in the morning as I was leaving to school three the key dash lit up as normal went to crank then just died and since then it’s been completely dead please help
File Type: mov
Old May 29, 2026 | 02:54 PM
lucky131969's Avatar
lucky131969
I hear a chime, see indicators on the IPC, and a gauge sweep.......so it's obviously not "completely dead".
- how do you know the battery is good? Has it been tested?
- If above is yes, what is the measured voltage at the battery?
Old May 29, 2026 | 03:42 PM
lionelhutz's Avatar
lionelhutz
If battery is good then check the battery connections and the cable connections from the battery to the starter solenoid and to the engine block.
Old May 29, 2026 | 07:01 PM
mmartinez's Avatar
mmartinez
Old May 30, 2026 | 09:16 PM
c5yazan's Avatar
c5yazan
3rd Gear
Thank you for the help I might be slow the connection was just loose all I had to do was tighten the terminals
To Please help my c5 isn’t getting any power
