cam&heads or supercharged?
Old Feb 23, 2003 | 06:11 PM
T-MAN's Avatar
T-MAN
Default cam&heads or supercharged?
cant decied on heads&cam or supercharged,shop down the street says,heads&cam he can get 125 hp more at tires!for about $6000.supercharger about $8400,i want something i can drive and not haveing to worry about heating problems.I want to be around 500hp at rear wheels and have driveabilty,so any one thats ben there done it can help me out. thanks 01 Z06,cold air induction,stainless works header,corsa x pipe,corsa indy with gtr tips.
Old Feb 23, 2003 | 06:19 PM
Quick Brick's Avatar
Quick Brick
Default Re: cam&heads or supercharged? (T-MAN)
From what you said I would say supercharge it. A stock displacement 500rwhp car is going to be a radical H/C car. Where as 500rwhp s/c is smooth as stock.
Old Feb 23, 2003 | 06:20 PM
C5JONNY's Avatar
C5JONNY
If I had the cash I would get the charger. (Just personal preference)
Old Feb 23, 2003 | 06:34 PM
T-MAN's Avatar
T-MAN
Default Re: cam&heads or supercharged? (C5JONNY)
im leaning towards supercharging but lots of guys saying,car runs hot, belt sliping.
Old Feb 23, 2003 | 06:52 PM
Bill Reid's Avatar
Bill Reid
Alot of the issues with the ATI kit have been worked out. I'd go with an ATI.
Old Feb 23, 2003 | 07:00 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: cam&heads or supercharged? (billreid1@***.net)
:withstupid:
Old Feb 23, 2003 | 07:15 PM
T-MAN's Avatar
T-MAN
Default Re: cam&heads or supercharged? (CHRIS NJ C5)
what about fuel pump,injecters.how much boost?howmuch hp can you really get supercharging a ls6.
Old Feb 23, 2003 | 07:29 PM
JTE's Avatar
JTE
CI 4-7, 9 & 10 Veteran
w/ 5psi and your longtubes you will probably right at or slightly above 500Rwhp.
Old Feb 23, 2003 | 07:30 PM
Bill Reid's Avatar
Bill Reid
On a stock LS6 I recommend the standard ATI LS6 pulley size. I think its a 4.25 for the P1SC. You'll get about 6.5 pounds of boost. Injectors come with the kit... and recommend an intake fuel pump upgrade. You'll get anywhere from 500-545 rwhp by doing nothing else to the car (assuming just the headers as an additonal bolt-on). Let us know if we can be of any help or if you need a quote.
[Modified by billreid1@***.net, 5:31 PM 2/23/2003]
Old Feb 23, 2003 | 08:19 PM
SideStep's Avatar
SideStep
If you have the coin go SC... :thumbs:
Old Feb 23, 2003 | 09:24 PM
CantHookUp's Avatar
CantHookUp
"From what you said I would say supercharge it. A stock displacement 500rwhp car is going to be a radical H/C car. Where as 500rwhp s/c is smooth as stock".
:iagree:
Go SC al the way....I bought my ATI kit from JD's Performance out of Florida and with install the total bill was $6700. You can't believe the power you will have :hurray: All I hope for is someone to challenge me. .. Anyone :D
:steering:
Old Feb 24, 2003 | 08:15 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: cam&heads or supercharged? (SideStep)
:iagree:
To cam&heads or supercharged?
