A4 Transmission Service
Old Feb 24, 2003 | 05:31 PM
Jettech's Avatar
Jettech
Default A4 Transmission Service
Can somebody please tell me where to add fluid to an A4 tranny on a 2000 coupe. I have looked all over the tranny, but don't see the fill port. Can you pour it in, or do you have to pump it in? :nonod:
Old Feb 24, 2003 | 06:01 PM
RskyBns's Avatar
RskyBns
Default Re: A4 Transmission Service (Jettech)
Just did this about two weeks ago on mine. There is a plug (bolt) on the drivers side of the car on the tranny pan. To refill you must pump it in through this hole. I bought a MityVac from Pep Boys for about $10 and worked out well.
Old Feb 24, 2003 | 06:02 PM
JCR's Avatar
JCR
A pump is required. The change is not difficult although you should read the procedure prior to attempting this service. Getting the vehicle up high enough to work underneath is crucial.
Old Feb 25, 2003 | 12:53 AM
Jettech's Avatar
Jettech
Default Re: A4 Transmission Service (JCR)
Thanks for the help! I found the plug, and now I better go buy a pump. :thumbs:
Old Feb 25, 2003 | 01:42 AM
Sam Lin's Avatar
Sam Lin
FYI, to full level for the A4 tranny is when the fluid is level with the bottom of the fill hole with the car RUNNING.
Sam
Old Feb 25, 2003 | 09:15 AM
Norris's Avatar
Norris
Default Re: A4 Transmission Service (Sam Lin)
Sam
Sam, that is with the gear selector in Park, isn't it?
Old Feb 25, 2003 | 02:47 PM
Sam Lin's Avatar
Sam Lin
Default Re: A4 Transmission Service (Norris)
Yes it is, manual says to hold the brake and shift into each gear position for 5 seconds, then return to park and check. It's not that bad to crawl under the car while it's running - the driveshaft is inside the torque tube, there's no moving parts to watch out for in the back - just don't burn yourself on the hot exhaust. I didn't have any problems, and that was when I was far from a mechanic.
Sam
To A4 Transmission Service
