Stock crank stroker? Please educate me.
No fun not driving a vette while it is down. Visiting hours every Saturday.
[Modified by lost, 5:41 AM 2/25/2003]
http://www.ls1tech.com/ubb/ultimateb...c;f=1;t=011181
http://www.ls1tech.com/ubb/ultimateb...c;f=1;t=010868
http://www.ls1tech.com/ubb/ultimateb...c;f=1;t=008409
http://www.jrmotorsports.net/
Go out to this site, and look under rods. There are about 100 sets for sale.
The formula for max torque allowable in a solid cylinder under a torque is:
torque = max_shear * (pi * r^3)
, where max_shear is the maximum shear strength of the material.
1.888 is about 90% of 2.1, and 0.90^3 is 73%, so a crank shaft 90% of the size of the original will be able to handle 73% of the torque, assuming the machining doesn't change the material properties, and ignoring the effects of cryo-treating.
That's how strong it ought to be, anyway.
JPR's got 382 all-bore short blocks for only $4200 (stock crank and rods). If you could add a 3.82" offset-ground crank for $500, you'd be at 404ci, and still under $5000.
There is NO loss in stength that will put you in danger going to a 1.888 rod journal if the crank is done properly. Bang for the buck you can't beat using a stock block and crank to make 396 ci's. Using the Carrillo rods that new go for $2,200, hell the rod bolts alone are $500 on these and that's what you pay for the whole set of these rods. That is an amazing deal!!!
You can get 3.822 out of a good crank without any spun journals of course. You have to allow 10-15 thou of clean up. So the total differnce in bearing size assuming STD bearing sizes is .212 - 12 thou cleanup will net around .200 of clean stroke increase. Also you can get a little more if you go with a 10-20 under bearing. But I would rather do a STD bearing so if you ever need to regrind it undersized it's still usable. Hope this helps.
[Modified by J-Rod, 9:49 AM 2/25/2003]
[Modified by J-Rod, 9:50 AM 2/25/2003]
[Modified by J-Rod, 9:51 AM 2/25/2003]
[Modified by J-Rod, 9:53 AM 2/25/2003]
