Water & Electronics (Yikes)
Old Feb 26, 2003 | 03:48 PM
Rick-M's Avatar
Rick-M
Default Water & Electronics (Yikes)
I had posted on this about 6 weeks ago regarding a non-start situation. To re fresh I parked the car came out and had no start, battery was good some items powered up some did not but no power to starter. Had it towed and after it sat for a day everything came to life again (no codes) I tried and checked all suggestions (for some reason I can’t find previous post). Now I have a new problem which is water in the left rear “cubby” hole. I also noticed moisture after I washed the car (I wash underneath). I am also getting a Traction Control Light when it’s wet.
The car had body work several months ago where the rear quarter was replaced; this could be the moisture problem. I checked and don’t see any electronics there, is there anything in that area that could be causing my problem?
