knocking and pinging when turned off
Old Feb 26, 2003 | 06:22 PM
2001trplblkvert's Avatar
2001trplblkvert
Cruising
Default knocking and pinging when turned off
When I turn off the engine my vette knocks and pings for 2-3 seconds. Other vettes (c5) I drove did the same. I was told its normal. Is this true?
Old Feb 26, 2003 | 06:36 PM
RskyBns's Avatar
RskyBns
Default Re: knocking and pinging when turned off (2001trplblkvert)
Mine knocks and pings when I drive it :rolleyes:
Old Feb 26, 2003 | 08:10 PM
wwashing's Avatar
wwashing
If it is an M6 and the clutch is in, it will demonstrate drive train rattles when you turn it off, but no engine knocks. It the engine knocks it is not normal.
If it an M6 and it is in neutral and the clutch is out, it should not rattle when turned off. :cheers:
[Modified by wwashing, 7:22 PM 2/26/2003]
Old Feb 26, 2003 | 10:11 PM
lost's Avatar
lost
Default Re: knocking and pinging when turned off (wwashing)
It sounds like you have one or more leaky injectors. ignition cutoff also cuts power to fuel injectors. It is not normal to get any kind of run-on. I suspect dirty injectors. My C5 will hold fuel pressure overnight.
Old Feb 26, 2003 | 11:13 PM
scool93535's Avatar
scool93535
I'd say not normal even with a manual trans. I've never experienced it in almost 2 years. If you have a good mechanic you trust, have them check it out. If not try a reliable dealer.
:cheers:
Old Feb 26, 2003 | 11:21 PM
Bill Dearborn's Avatar
Bill Dearborn
I haven't had a car do that in over 20 years. From what you are describing this is a lot more than the drive train rattle that all 6 speeds have when they are turned off.
Bill
Old Feb 27, 2003 | 01:58 AM
Cajun99's Avatar
Cajun99
Sure isn't any knocking and pinging in mine when I turn it off :nono:
Like the others stated there something more sinister going on there. :smash:
Old Feb 27, 2003 | 04:46 PM
Avanti's Avatar
Avanti
"...normal" Huh? This isn't normal for ANY engine run on the correct fuel. M
My '01 with 16K miles never has knocked or pinged, running or turned off. However, I use nothing less then 93-92 octane fuel.
All the best.
Old Feb 27, 2003 | 05:31 PM
jawski's Avatar
jawski
Default Re: knocking and pinging when turned off (Avanti)
a hot spot (high carbon buildup) in the combustion chamber would cause run-on..try de-carbonizing
To knocking and pinging when turned off
