Exhaust 'Pop' Question
Old Feb 27, 2003 | 12:09 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Default Exhaust 'Pop' Question
Last weekend (when we had decent weather here in Texas) I took the car out for a little run. I first drove on surface (local) streets. Incurred a lot of this exhaust ‘popping’, specifically when shifting between 1-2, 2-3. Made me some what uneasy, not to mention self conscious.
I accelerated onto the freeway (hope the law is not reading this) with a lot of WOT. Ran about 3 miles, then exited.
When I was again on the surface streets the exhaust ‘popping’ was much, much less noticeable.
Any thought on why this occurred?
Old Feb 27, 2003 | 01:08 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Default Re: Exhaust 'Pop' Question (AC54ME)
Just cold air rushing back in ... nothing to worry about normal on after market exhausts Tx here too
Old Feb 27, 2003 | 02:04 PM
johnC5's Avatar
johnC5
When the engine/exhaust are cold, you can get major popping and even afterfire (loud kaboom: with no cats flames too). This is common. If it bothers you, don't lift on decel such that engine revs load up the car when cold (use the brakes to slow down while in a higher gear). Given all of your mods, this sounds normal. For peace of mind, show or describe the behavior to your tuner.
Old Feb 28, 2003 | 12:27 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Default Re: Exhaust 'Pop' Question (johnC5)
It is my belief if it is not simply cold air rushing in on decel then the other reason it could possibly pop/backfire is simply the car is cold and running rich.
Old Feb 28, 2003 | 04:11 PM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
I don't know why this occurs, but I sure do miss that pop on my A4. My previous 6 speeds used to pop like crazy on decel. It was music to my ears.
[Modified by CorvetteSS, 4:55 PM 2/28/2003]
Old Feb 28, 2003 | 04:17 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Default Re: Exhaust 'Pop' Question (CorvetteSS)
Ya a4's dont generally have this occur as you would on a 6spd
Old Feb 28, 2003 | 05:33 PM
Carsnob's Avatar
Carsnob
... pop like cray on decel. It was music to my ears.
I love that sound too. The sound of horsepower.
Old Mar 1, 2003 | 12:03 PM
flipm's Avatar
flipm
Default Re: Exhaust 'Pop' Question (Carsnob)
I love it too! We need to form a support group for this! But... isn't this the sound a lot of people call the "motorboat" sound that they try to eliminate with an X-pipe?
Old Mar 1, 2003 | 04:40 PM
Cajun99's Avatar
Cajun99
Default Re: Exhaust 'Pop' Question (flipm)
...isn't this the sound a lot of people call the "motorboat" sound that they try to eliminate with an X-pipe?
Naw, the motorboat idle is very much related to using Corsa exhausts.
The popping is pretty apparent on the six-speed vs. the A4 while slowing down in gear. Push in the clutch or keep the revs low and you can pretty much get rid of it. Personally I like the popping but put a Magnaflow Xpipe in front of my Stingers to take some of the crispiness out of it. Now it's more like muffled explosions. :thumbs:
Listen to the Corsa's idle versus others...
http://www.jayleone.com/exhausts/
http://www.thx2.net/exhaust.htm
Old Mar 1, 2003 | 09:24 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
Default Re: Exhaust 'Pop' Question (Cajun75)
To all, thanks for the input.
I have attempted the solutions (rev's) suggested, and find some enhancements.
Old Mar 3, 2003 | 10:29 PM
lostsoulny's Avatar
lostsoulny
i like the rumble and pop :yesnod:
Old Mar 4, 2003 | 01:13 AM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
I love that sound. One of the reasons I like to leave the radio off.
To Exhaust 'Pop' Question
