more power
Feb 27, 2003 | 02:30 PM
more power
i like to get more power, but dont wanna spend 5grand for a supercharger. i have the ls6 intake ,long tubes, high flows ,and aexhaust. what would be the next logical move will keeping smoke legal :confused:
Feb 27, 2003 | 03:07 PM
St. Jude Donor '17
Re: more power (pdd000)
What about a set of gears to really drive the power feeling home? :steering:
Feb 27, 2003 | 03:53 PM
CI 3-5-6-7-8 Veteran
Spend 500-800 bucks on a cam!
Feb 27, 2003 | 06:38 PM
Heads and cam :yesnod:
Feb 27, 2003 | 07:41 PM
Re: more power (Cobra4B)
:iagree:
Feb 27, 2003 | 08:12 PM
im a pretty handy guy, i did all the other mods i have myself. could i do a cam myself and if so which one would i get. not to radical i want to be streetable and pass smog tests :confused:
o and do i need heads if i do as cam :confused:
Feb 27, 2003 | 09:16 PM
bump me :D
Feb 27, 2003 | 09:53 PM
I'm with the gears guy. I say do the 390 or 410 gears... like adding 50-75 hp. :)
Feb 27, 2003 | 09:57 PM
No, you do not have to install modified heads if you do the cam, many cams work very well with the stock heads. But installing heads will give you more HP in most cases.
Feb 27, 2003 | 10:01 PM
I'd go the cam route. You can pick up nice gains without breaking the bank.
Feb 28, 2003 | 06:53 AM
Re: more power (C5Longhorn)
Do both cam and gears. Of course, then you will need bigger rear tires!
