Clutch Noise Question
Old Feb 27, 2003 | 09:50 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Default Clutch Noise Question
Can someone tell me if your 6 speed car has this problem. When the car is running with the clutch out and you turn the car off it makes a rattling sound. If you turn the car off with the clutch pressed in, it sounds normal.
What could be the problem? The car has 16,000 miles on it and under warranty until 9/03
Old Feb 27, 2003 | 09:59 PM
0-60N4's Avatar
0-60N4
Default Re: Clutch Noise Question (Corvette ED)
Corvette Ed. Watch your video that came with the car. They tell you about this known design feature. Nothing to be alarmed about. Sounds like you have the same rear transmission that the rest of us do. It makes the same kind of sound if you let out on the clutch at too low of an RPM.
Old Feb 27, 2003 | 10:03 PM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
All my 6 speed Vettes did this. It's not nearly as annoying though as listening to the clutch rattle while letting the car idle with the clutch pedal not pressed.
Old Feb 28, 2003 | 06:09 PM
Corvette ED
Default Re: Clutch Noise Question (CorvetteSS)
That is what my car does. It rattles at idle with the pedal not in. It just sounds bad, I had someone riding in the car ask me what is that noise. I said can you believe GM thinks this is normal?
I guess there is no fix for this unless you replace the clutch!!!!!!
Old Mar 1, 2003 | 10:43 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The noise is gear rattle in the trans...With the clutch out,the drive shaft and mainshaft in the trans are rotating even though you are not moving.With the clutch in,it isnt...That is also why you get a pop noise when releasing the clutch when standing still,because you are quickly engaging the drive shaft and main shaft. :yesnod:
Old Mar 1, 2003 | 10:44 AM
Sean03's Avatar
Sean03
Ya mine rattles at idle tooo. I cant stand it. Will GM do anything about this?
Old Mar 1, 2003 | 03:56 PM
Corvette ED
Default Re: Clutch Noise Question (Sean03)
I would like to find out too!!!!!!!!!!!!!!!!!!!!
Old Mar 1, 2003 | 04:26 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Probably...on the C6. :rolleyes:
BTW, if you disengage you clutch slowly you'll find that the sound is far less notable.
[Modified by BQuicksilver, 4:27 PM 3/1/2003]
To Clutch Noise Question
