base and Z51 suspensions?
Old Feb 27, 2003 | 11:14 PM
illmac77's Avatar
illmac77
CI 7-8 Veteran
CI 8 Car Show Winner
St. Jude Donor '07
Default base and Z51 suspensions?
is there any difference in the stock height(gap from bottom of fender to top of tire)of a base sus. and Z51, on my vette a have right at a 2" gap between wheel and bottom of fender well all the way around, does this sound right for a stock clearence or after the bolts were turned to lower it, im not sure if it was lowered since i bought it as is, where my buddys vette base sus. after lowered has 3" gap front and longer bolts in rear giving him 1.5" gap.
Old Feb 28, 2003 | 07:17 AM
MiamiDave's Avatar
MiamiDave
Default Re: base and Z51 suspensions? (illmac77)
This seems to be one of the great unsolved mysteries... :rolleyes:
My 'Vette with it's base suspension was really high from the factory. I've since lowered it to the bolt stops-and it was still higher than most non-lowered factory cars!!
I think the Z51's are a little lower from the factory-but can't be sure.
Also, I think time and miles let's the car settle a bit. Mine seems to have gotten a bit lower.
It soes sound lowered though. Check your tire wear and it may be need to be realligned if the other guy didn't do it.
Old Feb 28, 2003 | 08:20 AM
VetteDrmr's Avatar
VetteDrmr
My friend's '97 coupe (stock suspension) and my '00 hardtop (Z51 std) were almost exactly the same height-wise before we lowered them.
Hope this helps,
Mike
Old Feb 28, 2003 | 09:21 AM
illmac77's Avatar
illmac77
CI 7-8 Veteran
St. Jude Donor '07
Default Re: base and Z51 suspensions? (MiamiDave)
had had an allignment done when i bought the car and just put on nitto's this week, your right though sounds like a mystery by the way mine is a 01 coupe and my buddys is a 00 coupe dont think that matters though, i also know that my front bushing are not cut and a still had the original bolts in the rear.
To base and Z51 suspensions?
