Z06 Clutch Assembly
Old Feb 28, 2003 | 06:43 PM
q4_99_vette's Avatar
q4_99_vette
Default Z06 Clutch Assembly
Ok I keep hearing that the 02 Z06 clutch assembly comes from GM 0 balanced. All the shops are telling me the same thing. So before I put this backtogether I want it right... don't worry about it or take it to a machine shop and make sure?
Old Feb 28, 2003 | 06:55 PM
Vette#4's Avatar
Vette#4
Default Re: Z06 Clutch Assembly (q4_99_vette)
I just had the Z06 assembly installed, but before it was put in at the
last minute I had it 0 balanced at a machine shop...good thing because
it was NOT 0 balanced...have the whole assembly 0 balanced - cost was
$30.00 :cheers:
Old Feb 28, 2003 | 07:02 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Z06 Clutch Assembly (Vette#4)
How did your car feel after you installed the new clutch that was 0 balanced by a machine shop.
Phillip
Old Feb 28, 2003 | 08:37 PM
CJS's Avatar
CJS
I put one in just as it came from GM. It is working fine, no vibrations. If I had it to do again, I would have it zero balanced, maybe it would be better.
Old Mar 1, 2003 | 08:09 AM
see5's Avatar
see5
I had a 02Z clutch installed by the dealer last Spring and it is fine but I may have been lucky. I would never again install any clutch without balancing. Cheap insurance.
To Z06 Clutch Assembly
