C5 heads spec
Cylinder Head Engine Block Deck Flatness (Measured within a 152.4 mm (6.0 in) area) 0.08 mm 0.003 in
Cylinder Head Engine Block Deck Flatness (Measuring the Overall Length of the Cylinder Head) 0.1 mm 0.004 in
Cylinder Head Exhaust Manifold Deck Flatness
0.22 mm 0.008 in
Cylinder Head Intake Manifold Deck Flatness
0.22 mm 0.008 in
Cylinder Head Height (Measured from the Cylinder Head Deck to the Valve Rocker Arm Cover Seal Surface)
120.2 mm (Minimum) 4.732 in (Minimum)
Valve System
Valve Face Angle 45 degrees
Valve Guide Installed Height (Measured from the Cylinder Head Spring Seat Surface to the Top of the Valve Guide) 17.32 mm 0.682 in
Valve Lash Net Lash--No Adjustment
Valve Lift (Intake) 11.99 mm 0.472 in
Valve Lift (Exhaust) 12.15 mm 0.479 in
Valve Lifter Hydraulic Roller
Valve Margin 1.25 mm (Minimum) 0.05 in (Minimum)
Valve Rocker Arm Ratio 1.70:1
Valve Seat Angle 46 degrees
Valve Seat Runout 0.05 mm (Maximum) 0.002 in (Maximum)
Valve Seat Width (Intake) 1.02 mm 0.04 in
Valve Seat Width (Exhaust) 1.78 mm 0.07 in
Valve Spring Free Length 52.9 mm 2.08 in
Valve Spring Installed Height (Intake) 45.75 mm 1.8 in
Valve Spring Installed Height (Exhaust) 45.75 mm 1.8 in
Valve Spring Pressure (Closed) 340 N at 45.75 mm 76 lb at 1.8 in
Valve Spring Pressure (Open) 980 N at 33.55 mm 220 lb at 1.32 in
Valve Stem Clearance (Production--Intake) 0.025-0.066 mm 0.001-0.0026 in
Valve Stem Clearance (Production--Exhaust) 0.025-0.066 mm 0.001-0.0026 in
Valve Stem Clearance (Service--Intake) 0.093 mm (Max) 0.0037 in (Max)
Valve Stem Clearance (Service--Exhaust) 0.093 mm (Max) 0.0037 in (Max)
Valve Stem Diameter (Production) 7.955-7.976 mm 0.313-0.314 in
Valve Stem Diameter (Service) 7.95 mm (Min) 0.313 in (Min)
Valve Stem Oil Seal Installed Height (Measured from the Valve Spring Shim to Top Edge of Seal Body) 18.1-19.1 mm 0.712-0.752 in
[Modified by WhiteC5Vette, 3:46 PM 3/2/2003]
1.55 " exhaust
:cheers:
Keith
Keith
