Metallic rubbing/hiss from rear
Old Mar 4, 2003 | 10:48 AM
Finch's Avatar
Finch
Default Metallic rubbing/hiss from rear
I'm getting a metallic hiss/rubbing and eventually squeaking from the rear. It occurs as the wheels turn, and is unaffected by application of brakes. The higher speed the car is going, the less you can hear it, but as I'm slowing to a stop light the "hiss hiss hiss" is heard each rotation of the rear wheels. It does not sound healthy! Anyone know what this could be? it's going in for warranty work so I would like some idea before telling them. Thanks in advance :yesnod:
-Pete
Old Mar 4, 2003 | 01:27 PM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: Metallic rubbing/hiss from rear (Pete99SS)
emergency brake is sticking.....it is adjustable
try to pull it up real hard about 10 times.....
if that fails...apply it a little while moving and let it adjust itself that way
I had the problem, but it is gone now
thanks
Old Mar 4, 2003 | 10:24 PM
Finch's Avatar
Finch
Default Re: Metallic rubbing/hiss from rear (Ram Air Tony)
thanks Tony, i'll try it as soon as I get my car back :thumbs:
-Pete
To Metallic rubbing/hiss from rear
