Brake Lights Don't Work - Need Help
Old Mar 4, 2003 | 10:51 AM
Red C5's Avatar
Red C5
Default Brake Lights Don't Work - Need Help
My passenger side brake lights don't work. The tail lights all work, all bulbs are fine. Any ideas? I tried to find a fuse for it but no luck (or skill). :smash: :cheers:
Old Mar 4, 2003 | 10:53 AM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
Default Re: Brake Lights Don't Work - Need Help (Red C5)
Have you done any mods to the tail lights such as installing euro's?
Old Mar 4, 2003 | 10:56 AM
SAXN8R's Avatar
SAXN8R
Default Re: Brake Lights Don't Work - Need Help (CorvetteSS)
:withstupid:
Red C5's Avatar
Red C5
No I haven't.
Old Mar 4, 2003 | 11:01 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
I had the same problem, chased my tail for weeks, checking bulbs, fuses, and wiring harness. Turns out the problem was actually the turn signal lever on the steering column. I had the entire unit replaced, and it has worked fine ever since. :cheers:
Old Mar 4, 2003 | 11:13 AM
Red C5's Avatar
Red C5
Default Re: Brake Lights Don't Work - Need Help (Godspeed)
What fuses?
Old Mar 5, 2003 | 12:06 AM
Red C5's Avatar
Red C5
Tough one to fix? :nopity
To Brake Lights Don't Work - Need Help
