Changing Tire Size
Old Mar 4, 2003 | 06:43 PM
budmont's Avatar
budmont
From: hamilton nj "Life's tough......It's even tougher if you're stupid."-John Wayne
Anybody know of a problem with using 245/40ZR17’s and 275/35ZR18’s on a 99 vert. :confused:
[Modified by budmont, 11:29 PM 3/4/2003]
Old Mar 4, 2003 | 09:57 PM
jrz01's Avatar
jrz01
Default Re: (budmont)
Is there a question here?
Old Mar 4, 2003 | 10:19 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Default Re: (jrz01)
damn and I had an answer!!!!
Old Mar 4, 2003 | 11:25 PM
budmont's Avatar
budmont
Default Re: (jrz01)
The question was “Is there a problem with using 245/40ZR17’s and 275/35ZR18’s on a 99 vert. After 30 views and no responses I figured the question was to hard, so I took it off. But since you asked I'll put it back!
Thanks for the reply!
[Modified by budmont, 11:31 PM 3/4/2003]
Old Mar 5, 2003 | 12:11 AM
99C5Richie's Avatar
99C5Richie
Since those sizes are not so far off from stock... you'll have no probs... :D But I gotta ask... why not go bigger :confused:
Old Mar 5, 2003 | 06:46 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I have the Nitto 555 Extreme 255/40/ZR17's in front and 285/35/ZR18's in rear on stock size OEM Y2K wheels. Fit and look great with no clearance problems. Adjust for the overall height difference with a Hypertech PP3. (approx .61" in front, .65" in rear)
:seeya
Old Mar 5, 2003 | 08:16 AM
C5 Frederik's Avatar
C5 Frederik
Compared to the OEM size 245/45-17 front and 275/40-18 rear, your new ones will be smaller, regarding Miata tire size caculator 3.8% too small in front and 4.1 % too small in rear. That´s the math. I do not know if other parts beside odometer (speedgauge) will be influenced.
Hope this helps a bit
Frederik
Old Mar 5, 2003 | 09:39 AM
budmont's Avatar
budmont
Default Re: (99C5Richie)
I can get them for $25 each :hurray:
Thanks to all for their input :D
Old Mar 5, 2003 | 09:45 AM
budmont's Avatar
budmont
Default Re: (C5 Frederik)
Frederik
Frederik, what is that Miata tire size calculator you mentioned. I know the sidewall is smaller but will this also effect the width :confused:
[Modified by budmont, 10:06 AM 3/5/2003]
Old Mar 5, 2003 | 09:56 AM
budmont's Avatar
budmont
Default Re: (Mike98SilVert)
:seeya
:iagree: Tires do look great :cool: Thanks for the info on the height difference, I never thought of that. I have a Hypertech PP3 which I haven’t used yet. I'll be sure to use your data when everything goes on. :hurray:
Old Mar 5, 2003 | 09:59 AM
MilYellow02's Avatar
MilYellow02
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
The sidewall will be too small IMO. I would say no :)
Old Mar 5, 2003 | 10:17 AM
C5 Frederik
Go to http://www.miata.net/garage/tirecalc.html
There you can compare two tires in diameter/circumdingsbums?
This has nothing to do with width, OK? But part of the complete diameter of a wheel is a percentage of the width. i.e. 275/40 means hight of the rubber/tire itself is 40% of 275 (width)
Sorry if I was too complicated. If any question, please ask.
Frederik
Old Mar 5, 2003 | 11:34 AM
budmont's Avatar
budmont
Frederik
Thanks :cheers:
Old Mar 5, 2003 | 12:10 PM
low flyier's Avatar
low flyier
how "wide" can you get on a vette tire without changing rims? :conehead
To Changing Tire Size
