X-Pipe
Old Mar 6, 2003 | 01:35 AM
MAC5's Avatar
MAC5
Default X-Pipe
I currently have Corsa Indy's installed on my 98. I'm considering installation of the Corsa x-pipe and would like some feedback from those that have the x-pipe installed. Does it completely eliminate the off throttle popping, or does it reduce it. I guess to reduce the subjective nature of the response, rank the reduction on a scale of 1-5 (5 being total elimination, 1 equals no change). What about the motor boat sound at high idle, any change? Also, does the x-pipe change the sound (tone, volume, any increase in resonance)??
thanks
MAC
[Modified by MAC27526, 12:36 AM 3/6/2003]
Old Mar 6, 2003 | 03:32 AM
C5 Frederik's Avatar
C5 Frederik
Default Re: X-Pipe (MAC27526)
It reduced popping, would rank it 4
motorboat sound at idle is much softer, nearly gone
sound is as if # of cylinders is double, no more resonance as I already had before, more exotic, not so hard, mellow,
Hope this helps
Frederik
[Modified by C5 Frederik, 9:34 AM 3/6/2003]
Old Mar 6, 2003 | 09:34 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: X-Pipe (C5 Frederik)
That pretty much sums it up. :yesnod:
vetterdstr :cheers:
To X-Pipe
