Z06 wheels- offset
Old Mar 6, 2003 | 10:21 PM
Wndotintman's Avatar
Wndotintman
Default Z06 wheels- offset
Does anyone know where the difference the offset is in a 9.5 vs 10.5 wheel. Is it in the rear(back) part of the wheel or the front of the wheel. Or is it .5 in front and .5 in the rear. Thanks.
Old Mar 7, 2003 | 07:23 AM
C5 Frederik's Avatar
C5 Frederik
Default Re: Z06 wheels- offset (97WhiteC5)
On my OEM Z06 Spedline rims offset is
front 54mm with 9.5, rear 56mm with 10.5
When you take a look at the outside, the rear spokes are designed more into the inside than the fronts, or to say in the rear the lip comes more out than in the front
With the above data you can make two little drawings (9.5 and 10.5 rim )and maybe get an answer by looking where the offset is located.
Frederik
OK was interested myself, so I did the math: from 9.5 to 10.5 rim
there is 2 mm offset difference and each lip is half inch more out/in
so if a 10.5 is mounted instead of the 9.5
the inner lip moves to the inside 12.7 plus 2 makes about 15 mm
the outer lip moves to the outside 12.7 minus 2 makes about 11 mm
Correct me if I´m wrong or misunderstood your question.
[Modified by C5 Frederik, 1:23 PM 3/7/2003]
[Modified by C5 Frederik, 2:10 PM 3/7/2003]
Old Mar 7, 2003 | 01:42 PM
davidfarmer's Avatar
davidfarmer
7 3/8 TOTAL backspacing on the 17x9.5, 8" TOTAL on the 18x10.5. So, the larger wheels site 5/8" further "in" and 3/8 further "out"
Dave
Old Mar 7, 2003 | 03:38 PM
Wndotintman
Default Re: Z06 wheels- offset (davidfarmer)
I didnt explain myself very well at all. What I am doing is putting Z06 wheels on my 97 C5. I was wondering where the inch difference is between the front 9.5 wheel and the stock 8.5 wheel. Is the extra inch on the Z06 wheel in the backspacing or in the outside of wheel. Sorry if i confused anyone. I know I did myself. Thanks. :thumbs:
Old Mar 7, 2003 | 03:51 PM
C5 Frederik
You manage to keep me busy like my sons do.... :smash:
OK, once again
old 8.5 has offset of 60 mm, new 9.5 has offset of 54, difference is 6mm
inner lip moves to inside 12.7 minus 6 makes about 7 mm
outer lip moves to outside 12.7 plus 6 makes about 19 mm
The 60 mm offset above is for Mags, do not know if its the same for waggon wheels
Frederik
Old Mar 7, 2003 | 04:25 PM
davidfarmer
Default Re: Z06 wheels- offset (C5 Frederik)
Here are my numbers, 3/8" of the extra goes inside, 5/8" outside. 7" total on the 8.5, 7 3/8 total on the 9.5
Old Mar 7, 2003 | 04:51 PM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
Bottom line ...they will bolt on with no problems at all. :D
Old Mar 7, 2003 | 08:57 PM
Wndotintman
Default Re: Z06 wheels- offset (iceburgh68)
Yes I know they will fit, I am deciding on which wheel I am going to go with. Thanks everyone for all the info. :steering:
[Modified by 97WhiteC5, 1:58 AM 3/8/2003]
To Z06 wheels- offset
