help w/CCW wheels 17x11 fronts
Old Mar 8, 2003 | 03:41 AM
bigDvette's Avatar
bigDvette
Default help w/CCW wheels 17x11 fronts
I just bought 17x11 fronts for 315tires from john at ccw. The clearance of the wheel is fine, however the outer edge on the backside of the rim (part where tire meets rim) grinds on my lower control arm. Cut a descent scar in it in about 2 seconds turning left full turn.
Has anyone experienced problems with rims rubbing on the lower control arm?
Old Mar 8, 2003 | 10:58 AM
bigDvette's Avatar
bigDvette
Default Re: help w/CCW wheels 17x11 fronts (bigDvette)
ttt
Old Mar 8, 2003 | 11:24 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Take a file and lightly file the A-arm where the rim comes in contact with the a-arm. 17 x 11 is pretty big for the front... is that the Road Course package you have there? My initial thoughts were you are bolting on the rears to the fronts... :crazy:
vetterdstr :cheers:
Old Mar 8, 2003 | 11:34 PM
bigDvette's Avatar
bigDvette
Default Re: help w/CCW wheels 17x11 fronts (vetterdstr)
Is there any risk in filing this down. Will it weaken it?
Old Mar 8, 2003 | 11:38 PM
vetterdstr's Avatar
vetterdstr
Chances are that you only need to file a very small area to obtain clearance. I did it on mine then proceeded to run my car on the Road Courses all across CA. :yesnod:
vetterdstr :cheers:
To help w/CCW wheels 17x11 fronts
