Alignment needed after cam swap?
Old Mar 8, 2003 | 11:45 AM
nozebleed's Avatar
nozebleed
Default Alignment needed after cam swap?
I had the steering rack out and the ball joints and steering rod disconnected.
Is this reason enough to throw me out of alignment? :confused:
Old Mar 8, 2003 | 06:05 PM
CJS's Avatar
CJS
Default Re: Alignment needed after cam swap? (nozebleed)
Mine did need the alignment. But on mine the whole engine was out also.
Old Mar 8, 2003 | 07:21 PM
jeanlucpicard's Avatar
jeanlucpicard
Depends. Did you disconnect the tie-rod ends? If so, you will want to have the car aligned to save those expensive tires. Simply pulling the rack and ball joints will not wreck your alignment. The tie-rod ends will.
I had Firestone perform a lifetime alignment when I installed my Firehawks. Cost was around $130 and I take the car in about 4 times a year for camber adjustments (especially during autocross season :D ) and it costs me 0$. All "under the warranty". A regular alighment runs around $60 so I thought the extra $$ was a good value for my needs.
SAVE THE WAVE :seeya :cheers: :cool:
Old Mar 8, 2003 | 08:58 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
quote:
"Did you disconnect the tie-rod ends? If so, you will want to have the car aligned to save those expensive tires. Simply pulling the rack and ball joints will not wreck your alignment. The tie-rod ends will."
CORRECT! Had this happen to me (tie rods removed, new tires required due to alignment issue).
To Alignment needed after cam swap?
