Another Harlan shift light instal location
Old Mar 9, 2003 | 05:34 PM
see5's Avatar
see5
Default Another Harlan shift light instal location
I thought this was in the line of sight and easy. The light mounts with strip of Velcro and the wire tucks directly into the HUD cavity on it's way under the dash. Time, 10 minutes plus wiring and holes, zero.
[Modified by see5, 6:57 AM 3/10/2003]
Old Mar 9, 2003 | 06:53 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: Another Harlan shift light instal location (see5)
Good idea, you dont even want to know how long it took me to put it in the center vent. And now its so far into my peripheral vision that its only really easy to see at night.
Eric
Old Mar 9, 2003 | 07:19 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Thanks, I might look into that location for mine, if it ever gets here. :rolleyes: :cheers:
Old Mar 10, 2003 | 07:56 AM
see5's Avatar
see5
Default Re: Another Harlan shift light instal location (racer44)
I got mine in a week but maybe he is beween "batches" or yours is stuck at the border. I am sure it looks very suspicious?
Old Mar 10, 2003 | 09:03 AM
ICULUKN-C5's Avatar
ICULUKN-C5
very cool.... those LEDs are bright as hell.... Mine lights up the entire cabin, so i put mine low.
Old Mar 10, 2003 | 08:22 PM
wickedvette's Avatar
wickedvette
Cruise-In II Veteran
How hard is it to wire in the shift light and where?
Old Mar 10, 2003 | 08:49 PM
alexWS6's Avatar
alexWS6
Default Re: Another Harlan shift light instal location (wickedvette)
:withstupid:
Old Mar 10, 2003 | 09:57 PM
see5's Avatar
see5
The hook up is really quite easy. There are only three wires: +12 volts, ground and tach which is attached to the white tach wire to the factory tach. Good directions come with the unit and it is self contained and easy to program to desired RPM. The thread below and others help you find the tach wire.
http://forums.corvetteforum.com/zerothread?id=380644
[Modified by see5, 8:58 PM 3/10/2003]
Old Mar 11, 2003 | 11:19 AM
Wolf1171's Avatar
Wolf1171
From: Winter Jam I and II Veteran, Bahama Jam 2005 Veteran
CI 4, 5, 7, 9 & 10 Veteran
St. Jude Donor '03-'05-'06-'08
Default Re: Another Harlan shift light instal location (ICULUKN-C5)
Looks great :cheers:
To Another Harlan shift light instal location
