Help-Gas Door not workingFuse-ok
Old Mar 9, 2003 | 11:08 PM
dar's Avatar
dar
Default Help-Gas Door not workingFuse-ok
My 97 gas door won't open. unless I use the emergency latch, Replaced the fuse which looked ok, and still no luck---need gas and tired of pulling that latch---Thanx in advance
Old Mar 10, 2003 | 09:54 AM
BlackandBlue's Avatar
BlackandBlue
Cruising
Default Re: Help-Gas Door not workingFuse-ok (dar)
I had the same problem on my 2000 coupe. It turned out to be the door release mechanism. (as opposed to the button in the console, the wiring, the fuse, etc.) I had it fixed under warranty, so i can't give you a price for the part.
I hope this helps
Old Mar 10, 2003 | 10:09 AM
tonyh2000's Avatar
tonyh2000
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03
Default Re: Help-Gas Door not workingFuse-ok (BlackandBlue)
Mt 2000 had same problem, had it replaced under warrenty. Mine was the switch.
Old Mar 10, 2003 | 12:48 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
To check the switch, remove it from the console, not a hard job, and connect the two wires. If the door still does not open, the likely problem is the actuator.
To Help-Gas Door not workingFuse-ok
