Car stinks after a hard run...
Mar 11, 2003 | 12:04 AM
St. Jude Donor '03-'04-'05
What's that burnt smell coming from? It went away after a while, but it was really strong after the run. :confused:
Mar 11, 2003 | 12:46 AM
Re: Car stinks after a hard run... (FNC80)
Does it kinda smell like eggs?.. If so its the gases or something like that from the cat. converter.
Mar 11, 2003 | 12:49 AM
Re: Car stinks after a hard run... (Black_C5)
Eggs? No, it was definitely a burnt smell...more from the rear, I thought.
Mar 11, 2003 | 03:53 AM
is your car a mn6? could be clutch? :cool:
Mar 11, 2003 | 03:58 AM
Drag or track run? I ask because it could be brakes and or tires you smell.
Mar 11, 2003 | 10:58 AM
Re: Car stinks after a hard run... (Chris18tx)
It's an M6, yes. The smell's gone by now, but it was quite strong at the time. :cheers:
Mar 11, 2003 | 10:59 AM
Re: Car stinks after a hard run... (CPT Z06)
Quote:
Drag or track run?
Drag. I don't think it was the tire. I know that smell :) This had more of a metallic element to it.
Mar 11, 2003 | 11:54 AM
Alex I know you got the rear end differential fixed, check for any leaks again. This happen to me and I got a smell from the rear, it was a leak again :mad . Good luck!!
Mar 11, 2003 | 02:10 PM
Make sure your Parking brake shoe is not dragging. :cheers:
Mar 11, 2003 | 02:15 PM
Re: Car stinks after a hard run... (wwashing)
I get what may be a similar smell, especially in reverse. How to diagnose the possibility of a dragging parking shoe???? :confused:
Mar 11, 2003 | 03:42 PM
FNC80, Unfortunatly I've found this to be normal. I had it on my '00 6 spd coupe, (I thought there was something wrong too) and my '01 6 spd vert. Stinks to high heaven. It does get better as miles are put on , but the clutch lets out a stink if you slip it even a little. :U
Mar 11, 2003 | 10:47 PM
:iagree: :iagree: :iagree: :iagree: :iagree: :iagree:
:seeya :seeya :seeya :seeya :seeya :seeya
