EGR Elimination?
Old Mar 11, 2003 | 07:48 AM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
Default EGR Elimination?
Hope this isnt a bother. I'm usually over in C1/C2. I'm building a Corvette hotrod with LS1 engine. Can I remove the EGR set-up without causing problems. I'm trying to clean-up the engine compartment.
Thanks. :D
Old Mar 11, 2003 | 08:48 AM
rockgt302's Avatar
rockgt302
St. Jude Donor '05
Default Re: EGR Elimination? (vettes1st)
Where did you get the engine, I may be wrong but I dont think the vette has egr on the ls1. The F-bodies do up to 2000. I had a 98 f-bod, I took it all off and used ls1 edit to remove it from the pcm. I hope this helps or someone can give a better reply
Chris
Old Mar 11, 2003 | 09:09 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: EGR Elimination? (rockgt302)
Absolutely.. If you have an EGR or the airpump, you can remove them in a hot rod.. You will need to program them out in the PCM to keep from getting codes though. :seeya
To EGR Elimination?
