Piston diameter - size point ?????????
Old Mar 11, 2003 | 01:43 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Piston diameter - size point ?????????
Okay ,I'm trying to mic a set of LS6 pistons .Shop manual says to measure at size point- where the hell is that on the piston???? Thanks in advance. :confused: :yesnod: :cheers:
Old Mar 11, 2003 | 05:35 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Piston diameter - size point ????????? (binksZ06)
anybody???????????????????????? :cheers:
Old Mar 11, 2003 | 07:27 PM
steve keen's Avatar
steve keen
you want to measure the piston 90degrees from the pin,this is what you need to base clearance from,NOT THE SKIRT, hope this helps, :seeya steve
Old Mar 11, 2003 | 08:16 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Piston diameter - size point ????????? (steve keen)
Steve- Huge help, Thanks alot!!! I've been measuring the skirt!! ( I like skirts :D ) :thumbs: :cheers:
joel
To Piston diameter - size point ?????????
