Voiding warranty
Old Mar 11, 2003 | 04:48 PM
C5B's Avatar
C5B
Default Voiding warranty
I am about to void my warranty by changing the heads/cam on the vehicle. How can I minimize the possibility of the dealer 'noticing' my changes?
Does the factory apply Glyptol (or something like it) during engine assembly?
The heads I am putting on have the '241' casting, so that won't be obvious. I know if they pull the valve covers they'll see the shims, so I'd be screwed right there. I don't intend to have the dealer perform engine work, but I may have them do peripheral things like alternator, A/C compressor, PCM, etc.. Basically, the things that I know I didn't 'break' will be handled by them.
What things do I need to do when I do the R&R to keep it looking like a factory job? I am not changing anything else on the vehicle, so it will look and sound stock.
Thanks!
- C5B
Old Mar 11, 2003 | 08:02 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Default Re: Voiding warranty (C5B)
http://forums.corvetteforum.com/zerothread?id=509768
I can't help, but I'm thinking of robbing the Wells Fargo office in downtown San Francisco next tuesday at 2:45 pm. Do any of you have any tips for me? :hat
Sorry - couldn't resist.
Old Mar 11, 2003 | 08:03 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Basically for GM to refuse to pay warranty on warranty items, they must be able to prove that the modification affected the damaged part. Changing your heads does not affect the generator, A/C compressor, etc.
Also understand that laws vary between states, and in some states, it is more difficult for GM to void the warranty.
Also, technically a dealer can't void a warranty, since they do not offer the warranty, the warranty is offered by General Motors Corp. Dealers are private enterprises. They can contact GM, who will decide if the part voids the warranty.
Old Mar 11, 2003 | 08:08 PM
Mike Mercury's Avatar
Mike Mercury
probably not what you want to hear, but just accept the fact the warranty on your engine, tranny, and the rest of the drivetrain are NLA.
That's a decision we all have to make when doing power improving mods to our newer C5's.
Old Mar 11, 2003 | 09:08 PM
C5B's Avatar
C5B
Default Re: Voiding warranty (Mike Mercury)
Damn. Okay, so I take it NLA is synonymous for SOL :cry Really, what does NLA stand for?
I think it means I am on my own :yesnod:
Thanks!
- C5B
Old Mar 11, 2003 | 09:17 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I'm gonna take a stab at this and guess it means "No Longer Applicable".
SOL would be a better term if you toast the motor or drivetrain afterwards though. :D
:cheers:
Old Mar 11, 2003 | 09:19 PM
Mike Mercury
No Longer Applicable.
I wish I had your hutspa (sp) to do a head & cam upgrade. I'm too scared about losing my engine/drivetrain warranty... so I instead chickened out. :sad:
Old Mar 11, 2003 | 10:24 PM
C5B's Avatar
C5B
Well, since I am doin' the work myself, I guess I'll be doing it again if I believe that a serious $$$ problem would lead to an investigation at the engine. I am sure that a fried differential would not lead to removing the valve covers.
I do believe that what comes around goes around (bad karma and all that). I really wouldn't expect GM to fix a problem that I created.
Alright, I have my answer..... kind of :)
Thanks! :cheers:
- C5B
Old Mar 11, 2003 | 10:55 PM
ambitin's Avatar
ambitin
I think that if you find the right dealership, your warranty results will vary.... I've had considerable warranty work done AFTER heads/cam/mcleod dual disk, etc... including drive train work caused by my rear differential leaking. They know my car is modded but they also know the leaking wasn't caused by the mods so they fixed it. But again, you have to have an understanding/fair dealership. By the same token, I don't abuse my warranty coverage. I blew up my rear differential at the drag strip about 2 weeks after the dealership did all their work on it but I didn't bring it back to them- I took it to MTI and paid for those repairs because I knew they were my fault.
I have GMPP on my car.
Good luck,
Justin
Old Mar 11, 2003 | 11:23 PM
Don't know how GM assembles the engine, but for them to deny warranty coverage, the failed part would have to be related to the modification you did. Find yourself a mod friendly dealer and discuss with them. That way, you know what to expect.
Old Mar 12, 2003 | 12:33 AM
bowtiebandit's Avatar
bowtiebandit
Default Re: Voiding warranty (JDs00PewterCoupe)
Personally I don't care what you have done to the car but as was previously stated,don't expect coverage on a modified component. Each AVM has his own views on warranty expense and what is related and what isn't.
Old Mar 12, 2003 | 01:35 PM
C5B's Avatar
C5B
Default Re: Voiding warranty (ambitin)
I agree completely. I'll be asking questions of the three dealers in my area.
Thanks!
- C5B
Old Mar 12, 2003 | 02:02 PM
MySea6's Avatar
MySea6
Thanks!
- C5B
:thumbs:
Old Mar 12, 2003 | 04:03 PM
cselz's Avatar
cselz
:iagree: Worked for me....they'll even do the install (maifold, rear gears, etc). Just ask around.
:cheers:
-Chris
Old Mar 12, 2003 | 06:47 PM
WhiteC5Vette
Default Re: Voiding warranty (cselz)
There are laws on voiding a warranty, and basically in layman's language it states:
A manufacturer may not reject a warranty claim only because an aftermarket item is present. Warranty work can only be denied if an aftermarket part caused the failure being claimed under warranty.
Most states have agencies that will step in and fight for your warranty rights.
Old Mar 13, 2003 | 03:26 PM
Mitch Alsup's Avatar
Mitch Alsup
Default Re: Voiding warranty (WhiteC5Vette)
So what you are trying to say is that: (for example)
A) Chevy engineered the connecting rods and setup the rest of the engine for lonmg life at 350 FWHP;
B) You added a set of heads and cams, raised the red line and end up with 450 RWHP;
C) then find a connecting rod failure;
that Chevy should warentee a part that is now obviously overstressed?
It is just plain wrong to blame Chevy for this failure, as it would not have happened if the engine were left alone.
Whether you can get Chevy to pay for thie abuse is one thing, and Chevy may pay for it just to keep you happy, but remember it does end up RAISING the cost of cars over time, effectively, making those who don't mod their cars pay for those who do. This is just wrong.
<donning flame protecting suit--flame away>
Old Mar 13, 2003 | 06:25 PM
WhiteC5Vette
Default Re: Voiding warranty (Mitch Alsup)
From the original post I took it the person was asking about components that would not be affected by changing the heads, cam, etc. I cannot see how an A/C compressor, or generator would be damaged by this change. I'm just trying to say in my previous posts that GM must prove the modification damaged the part being replaced.
I agree, if someone adds a blower, changes the heads, cam, etc., then blows a rod, GM should not be liable for the repair.
Old Mar 13, 2003 | 07:34 PM
C5B's Avatar
C5B
Wow. Being that you didn't quote a post, I am assuming you aren't referring to me :)
Actually, my short block is engineered for at least 405fwhp as it's the same as the LS6. So, in theory, if I were to change to LS6 heads/cam and reach 405fwhp, then a blown rod would be well within Chevy's liability..... in my opinion :) But, I still wouldn't expect them to handle it. I AM referring to peripheral components, not the long block.
I did say, in a previous post, that wouldn't expect them to cover a problem that I created. I wouldn't expect them to replace my valve springs because they cracked if I revved it up to 6000rpm @ 30 degrees F. I WOULD expect them to replace my radiator if it developed a leak 10,000 miles after I removed/replaced it during the head/cam swap.
Folks, I am not stupid, just inexperienced with new vehicle warranties and modifications. This will be that last time I view this thread as some people are assuming I am trying to cheat the system. I have a few friends that take advantage of everyone and everything that they can; I despise that part of their character.
:cheers:
- C5B
To Voiding warranty
