Lowering Bolts...size?
Old Mar 11, 2003 | 11:32 PM
finnjeff's Avatar
finnjeff
Default Lowering Bolts...size?
I have seen this post before. What are the right size bolts to buy to lower my Z06. I dont want to pay top dollar for a kit I can make up from nutz&boltz
Jeff
Old Mar 12, 2003 | 12:05 AM
corvette dave's Avatar
corvette dave
Default Re: Lowering Bolts...size? (finnjeff)
The correct diameter bolt for the rear is 9/16". Some people are using 1/2" but I would not use those unless you could not find the 9/16".
A 7" bolt is usually used for the rear to lower beyond stock but a 6 1/2" bolt will work if you do not want to lower more than 2" beyond the stock ride height. The stock bolt is 6" but only has threads on 5 1/2" of it.
I think grade 8 is what you need. Get some washers and locking nuts and you are set.
Dave
[Modified by corvette dave, 11:08 PM 3/11/2003]
Old Mar 12, 2003 | 01:26 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Lowering Bolts...size? (corvette dave)
9/16" is the ideal size, but I am going to disagree with Corvette Dave about not using the 1/2" bolts. There are hundreds, who knows maybe even thousands of Corvettes :D using 1/2" bolts with absolutely no problem. I have mine up on my 4 post lift all the time and I regularly check under my car. My 1/2" bolts and bushings look perfect, no wierd wear or damage etc. My last three C5's all were lowered this way with no problems. If you road race your car every weekend, then maybe I would think twice about the 1/2", but then again maybe I would still use them. Who knows! :cheers:
Old Mar 12, 2003 | 08:34 AM
jawski's Avatar
jawski
6-1/2" will give you more than enough adjustment.
I tried 7" and the leaf spring was barely pre-loaded, rough ride.
Old Mar 12, 2003 | 05:18 PM
corvette dave
Default Re: Lowering Bolts...size? (jawski)
Racer,
I did say only use the 1/2" bolts if you could not find the 9/16'. No need to disagree. You said the same thing. ;)
I would search high and low before I would put 1/2" bolts in mine. That's me.
Jawski,
I think we have down this road before. If the 7" bolts are too long aren't there enough threads to just tighten the bolts and get some preload?
The reason I say this is that I only lowered mine 1" with 7" bolts. Did I get a set of bolts with more threads than normal? :)
Just curious.
Dave
Old Mar 12, 2003 | 05:46 PM
Racer's Avatar
St. Jude Donor '11
Racer,
:cheers: Just wanted to make sure he knew that if he did go with 1/2" he would be OK. :thumbs: :cheers:
Old Mar 12, 2003 | 08:36 PM
finnjeff's Avatar
finnjeff
Default Re: Lowering Bolts...size? (racer44)
Racer44,
Your Z06 looks great. I want to lower my Z06 but was told that I can't lower the front anymore than 1/2" on 02-03 Z06's. Is this true? Did you have to cut bushings on your front?
Thanks,
Jeff
Old Mar 14, 2003 | 04:32 PM
MachOne's Avatar
MachOne
Ok so 9/16x6 1/2 in the rear for bolts, but what do you do with the front. Sorry but I haven't read much about this. Thanks.
To Lowering Bolts...size?
