2001 z06 steering limiter
Old Mar 12, 2003 | 09:37 AM
bigDvette's Avatar
bigDvette
Default 2001 z06 steering limiter
I've been told that the z06 2001 model has the same steering column as the c5, but it has a limiter that limits the turning diamater which is not on the base cars which is why the turning radius is larger on the z06.
Do you know the part number and is it installable on a coupe. The reason I want it is simple. I am running 17x11 wheels up front that just barely rub and don't have this problem on a z06. I could add a spacer but thought I would at least investigate this option.
