Climate control display
Old Mar 13, 2003 | 07:36 PM
Flyhigh12's Avatar
Flyhigh12
3rd Gear
Default Climate control display
My '98 climate control works but the digital display doesn't. Initially, it came on and off periodically. But now it's not displaying anything (but the air/heat works fine). Any ideas?
Old Mar 13, 2003 | 07:55 PM
shafman1's Avatar
shafman1
Default Re: Climate control display (Flyhigh12)
I haven't messed with mine, but I've seen Radios with digital displays go out due to the small bulbs that back-light the LCD display.
If you are sure it is the unit itself and all the rest of your lights are working, I would check those. If you could take the unit out, I would try to see if you borrow one just to swap in real quick. Then, you would know for sure. :confused: :thumbs:
Old Mar 14, 2003 | 12:06 AM
kp's Avatar
kp
The climate control and radio in a C5 is flourescent, like a vacuum tube sorta :) They dont have a backlight like tho\e old ford radios.. I have fixed a couple that had cold solder joints but its much easier to buy a new (or used) control head. they pop up here and on eBay occasionally. They were 200 new the last time I checked if I remember. Can usually find a used one for 70-100.00. Takes about 15 minutes to change.
Old Mar 14, 2003 | 12:38 PM
2KVetteMan's Avatar
2KVetteMan
ASk forum member Karshop, he can get you one most likely. Cheers!!
To Climate control display
