how much can a4 handle?
Old Mar 14, 2003 | 12:50 PM
gaww's Avatar
gaww
Default how much can a4 handle?
how much power can a stock 2001 a4 transmission handle? which mods would be the limit for the car? i dont plan to stomp the pedal all the time, just the occasional spirited run on the highway. not too many empty roads here in chicago. would like a much better throttle repsonse though, esp with all the rice around here. the rice on the roads i mean, not in my kitchen. :rofl:
Old Mar 14, 2003 | 03:28 PM
Mitch C's Avatar
Mitch C
Default Re: how much can a4 handle? (gaww)
How well your stock A4 tranny holds up depends ALOT on how you drive your car. Even with a stock engine if you constantly beat on your car more than likely you will need to rebuild your transmission sooner or later. If you do heavy duty mods like H/C or a S/C or you run nitrous more than likely you will need a rebuild sooner rather than later.
[Modified by Mitch C, 3:03 PM 3/14/2003]
Old Mar 14, 2003 | 03:47 PM
vstella's Avatar
vstella
You can probably go with the typical bolt ons..Intake system..exhaust headers and free flowing cat back exhausts..Once you get into the engine with Heads and cam, also consider a better performance transmission. They are not very well built for higher H.P. OR...Just go with a Transgo shift kit and and a PCM tuning and get better shifts and better response overall..:D
More Info about the Transgo here..http://www.txchange.com/transgo.htm
Old Mar 15, 2003 | 12:06 AM
White657's Avatar
White657
You can do an intake and exhaust safely on the stock trans.
I'm currently tempted to do headers, but I'm still under warranty so I will probably wait it out.
Try an intake, like Blackwing, it will really liven the car up. :smash: :smash:
To how much can a4 handle?
