SLP 1.85 roller rockers
Old Mar 17, 2003 | 05:40 AM
vettesurfer's Avatar
vettesurfer
Default SLP 1.85 roller rockers
Have any of you guy tried these on a mildly modded c5? What kind of results? Are the worth the money? :flag
Old Mar 17, 2003 | 09:24 AM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Default Re: SLP 1.85 roller rockers (vettesurfer)
Mine were put in when I did my heads/cam etc so I can't say, but Roger Vinci designed these with crane and put them in my car and others and has averaged in the 14rwhp range basically because it gives your cam more lift and reduces friction, I have read claims of 10 to 18rwhp and a recent post the guy put them on a basically stock car and got 10rwhp pretty much throughout the range, I would be interested in this also I am going to deff put them on my stroker motor but I may have to go to the 1.7 as my cam will already be a little over 600 lift and there may be clearance problems.
Old Mar 17, 2003 | 10:47 AM
cscollis's Avatar
cscollis
I did the crane 1.8 rockers and got 8rwhp troughout the rpm range.
Old Mar 17, 2003 | 09:19 PM
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
Default Re: SLP 1.85 roller rockers (cscollis)
Sweet!
Old Mar 17, 2003 | 09:30 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: SLP 1.85 roller rockers (snide)
will there be problems using the SLP 1.85 roller rockers with stock LS1 cam and heads?
Old Mar 17, 2003 | 09:40 PM
Z06 Quin's Avatar
Z06 Quin
It appears that with the LS1 camshaft it's okay, but with the LS6 Camshaft new springs are recommended..
CLICK HERE FOR MORE INFO :cheers:
Old Mar 27, 2003 | 01:53 AM
patriot's Avatar
patriot
Default Re: SLP 1.85 roller rockers (Z06 Quin)
If you decide to install a cam down the road do the rockers have to be removed? :flag
Old Mar 27, 2003 | 03:04 AM
DieL's Avatar
DieL
Default Re: SLP 1.85 roller rockers (patriot)
No. Maybe if the lift of the new rocker isnt factored into the specs of the new cam, but if it is, NO.
I had my heads ported lightly and got a valve job. Better springs and retainers and pushrods too. I have a stock cam. I also raised the limiter 300 more rpms. I gained approx 40-60 hp from this. I went from 13.0 @ 111 to 12.60s @ 117.7
mph on Runflats. :flag
To SLP 1.85 roller rockers
