Need help with lowering issues??????????
Old Mar 18, 2003 | 07:03 AM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default Need help with lowering issues??????????
Need to get a few questions answered in reference to lowering my corvette on stock bolts.
1. How far can I lower the front
2. How far can I lower the rear
3. What size and how long should the bolts for the rear be in order to not have to cut the bushings
4. Can I buy the bolts at a hardware store or do I have use the ones that are especially made for this application (ie. mid america)
5. Will this process be fairly simple if the car is lifted up on a hydraulic lift
6. How far should I drop the rear and front if going to 275/35-18 tires all the way around
Thank you for your assistance in advance.
Old Mar 18, 2003 | 07:57 AM
Crushinator's Avatar
Crushinator
Default Re: Need help with lowering issues?????????? (ccajun4real)
Without cutting the bushings...not going for maximum lowering
1. front 1"
2. rear 1.25"
3. you can use the stock bolts
4. Yes, but make sure they're grade 8 bolts
5. extremely simple
6. front, back the bolt all the way out until the bushing is tight against the control arm. Loosen the rear until there are 2 threads showing. It will seem odd, but you're actually spreading the bushings apart. This in fact will result in the car sitting 1 1/4" lower.
I did my Z06 yesterday, and without cutting any bushings was able to lower the front 1" and the rear an inch and a quarter.
Old Mar 18, 2003 | 11:12 AM
COOL Z06's Avatar
COOL Z06
Default Re: Need help with lowering issues?????????? (Nat02Z06)
1. front 1"
2. rear 1.25"
5. extremely simple
:iagree:
If you want to go a little lower in the rear you will need 9/16-18 x 6-1/2" or 7" long Grade 8 bolts with Nyloc nuts. (Don't get too carried away with the longer bolts though because you'll bottom out with your stock shocks!!) :crazy: :eek: :yesnod:
[Modified by COOL COUPE, 1:09 PM 3/18/2003]
Old Mar 18, 2003 | 11:35 AM
0Cajun @ Edgyvette
Former Vendor
Thank you for all the advice. It really helped.
Old Mar 18, 2003 | 11:41 AM
89L98Coupe's Avatar
89L98Coupe
My C4 is lowered. I bought grade 8 bolts for $9 each. DO NOT USED HARDWARE Crap.......danger :steering: :auto: :cool:
Old Mar 18, 2003 | 04:01 PM
Jack Behrle's Avatar
Jack Behrle
Nat--After lowering, can you still get in driveways and over speed bumps? My '99 FRC w/z06 wheels and tires (F1) is constantly scraping and is it really stock. I would love to lowe say a half to 3/4" but as it is now, I scrape more than you would expect.
How do you guys lower 1.5" and actually drice anywhere????
Jack
Old Mar 18, 2003 | 04:27 PM
C5B's Avatar
C5B
Default Re: Need help with lowering issues?????????? (Jack Behrle)
I lowered mine 1-3/8" (cut one rib off front bushing) and then installed the A&A wheels on the front skid bars. Now, all I hit is the spring-loaded air scoop and the little wheels. I also installed the A&A rocker rail protectors to protect against damage during a high-center of the car. It makes a lot of noise, but doesn't do any damage.
- C5B
Old Mar 18, 2003 | 04:29 PM
Crushinator
Jack,
When I had my '97 I had it lowered as far as you could take it. And yes, it scraped everywhere. The was I have the Z06 lowered, I don't think scraping will be a problem. To get in my townhouse complex, there is a deep dip you have to go over and it doesn't scrape that. I think if you approach driveways and speedbumps carefully, you shouldn't have to worry at all about dragging.
Old Mar 19, 2003 | 10:50 AM
Avanti's Avatar
Avanti
Unless you drive on a "pool table" a lowered Vette IS going to drag. If all you use your C-5 for is Sunday cruising it might work--if real transportation, forget it.
All the best.
Old Mar 19, 2003 | 11:57 AM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Default Re: Need help with lowering issues?????????? (Avanti)
All the best.
Lowered Vette here. Does not drag, scrape or rub at all. :D Good thing I only drive on this pool table. :crazy: By the way this is my daily driver. Real transportation. :cheers: Lower it and enjoy. My car is only lowered as far as the factory bolts will take it.
Bob
[Modified by 16Again, 12:21 AM 3/20/2003]
Old Mar 19, 2003 | 12:47 PM
GaryZ06's Avatar
GaryZ06
Default Re: Need help with lowering issues?????????? (16Again)
:iagree: :iagree: :iagree:
Old Mar 20, 2003 | 04:24 PM
Jack Behrle
Nat--Thanks for your reply! Thinking of just lowering a little..perhaps 1/2 or 3/4 so I can still get over normal roads.
Regards
Jack
Old Mar 20, 2003 | 05:17 PM
Crushinator
All the best.
If you do a full "slam" then yes, I would agree with this. Just lowering 1" front and rear will not result in dragging everywhere. Even if it is your daily driver. :seeya
Old Mar 20, 2003 | 05:27 PM
DucaT's Avatar
DucaT
When I bought my car it was max lowered.
The adjuster bolts were spun all the way out. Damn thing scraped on everything, and the whole time I thought that this was stock!!!
I couldn't imagine someone lowering it even further.
Well, last weekend I finally got around to raising it up to a more normal height. Pretty drastic improve in ride quality and obstacle/speed bump/driveway negotiability.
I left it dropped 3/4", which is about perfect. That's what I'd shoot for if you drive it for more than aesthetics. Lower it too much, and it will bottom out alot, causing the bumpstops to come into play. Can make for some less than optimal handling characteristics.
I had to find that out on a bumpy German backroad at 110mph. Not fun.
To Need help with lowering issues??????????
