UPDATED! Shiftlight install DIY
Old Mar 18, 2003 | 07:50 PM
minivette's Avatar
minivette
Default UPDATED! Shiftlight install DIY
http://www.zee-oh-six.com/install_pa...ht_install.htm
Here's the updated DIY. I redid the format from the previous install doc.
Lemme know what you think. :steering:
Old Mar 18, 2003 | 08:57 PM
99Z51R's Avatar
99Z51R
Cruise-In III Veteran
St. Jude Contributor '04
Default Re: UPDATED! Shiftlight install DIY (minivette)
minivette, nice write up, I just did mine also.
Eric
[Modified by 99Z51R, 7:58 PM 3/18/2003]
Old Mar 18, 2003 | 09:07 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Nice job! Very easy to follow.Thanks. :cool: :yesnod: :yesnod: :thumbs: :cheers:
Old Mar 19, 2003 | 08:14 AM
minivette's Avatar
minivette
Default Re: UPDATED! Shiftlight install DIY (99Z51R)
Thanks everyone. :chevy
99Z51R, I like your install too. :steering:
Old Mar 19, 2003 | 10:34 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Minivette, nice job. Quick question - is the power hookup that you used in the passenger footwell the same power supply as would be used if you were hardwiring your radar detector? If so, I assume you could (physically at least) hook up both to this power supply, but would there be a concern as far as the amount of power draw (load) is concerned? Possible fuse problems? Thanks.
Old Mar 19, 2003 | 10:50 AM
iwannac5's Avatar
iwannac5
nice job on the write up, you put it into very simple terms that even someone not technically minded should be able to follow. thanks for sharing. :cheers:
Old Mar 19, 2003 | 11:28 AM
minivette's Avatar
minivette
Default Re: UPDATED! Shiftlight install DIY (wamara)
Yes, that would be the same wire and you can physically hook both to it. Judging by the size (as I do not know the load of the light or the radar detector)of the shiftlight wire, which is very small, I think it would be fine.
I have heard of issues when a shiftlight is physically mounted near the V1. When the shiftlight (light) goes off, the V1 will detect a laser signal. However I think V1 has a fix for this.
Old Mar 20, 2003 | 03:44 PM
wamara's Avatar
wamara
Minivette, thanks for the reply.
To UPDATED! Shiftlight install DIY
